bug in deep channel kernel
salvation
hi
in version 1.0 beta 3.01 an all before, ther is a bug in in the deep channel kernel..
if i go to position or Z deep there will be white/black pixel in the image..
with more rendertime, there will come more fault pixels in the image...
i also tried cuda 3 and cuda 4 driver
Win7 64 | Geforce 470GTX 1280MB | Q9550 2.83GHz | 8GB Ram | NVidia 306.23 , Cuda 5.0.1
FooZe
Hi Salvation,
Thanks for reporting, enabling the alpha channel should fix this.
Cheers
Chris.
salvation
it works!
thx
salvation
hi
in the new bet303 release the fireflies are gone but now in the other channels, the edges are hard aliased.
if i enable alphachannel all is fine
-> in the previous release the edges were antialiased (smooth)
-> is this a new bug or wanted?
abstrax
salvation wrote:hi
That is wanted, because antialiasing changes the color at the edges and with that the values that are represented at the edge.
With an alpha channel edges appear smooth, but that's only, because the alpha channel makes edges fade out smoothly, while the actual RGB values are still non-antialiased.
Marcus
