MAX2Octane exporter for max 2008-2009
kilaD
**MAX2Octane exporter for max 2008-2009**
1.022c 2008-2009 version
- Translates camera roll to Octane
- Added a button "New" under project config
NOTE: Users of max 2008 must download the guruware obj exporter here: http://www.guruware.at/main/
When reporting bugs, try to explain the steps in detail + MAXversion and version of the script
INSTALL:
Extract in max root folder, restart max.
Find the script in customize, under category max2octane.
max2octane_1.022c 2008-2009.rar
MAX2Octane 1.022c
- for max version 2008-2009
(7.89 KiB) Downloaded 770 times
Hello
foxid
Thx Kila
q6600 gtx275 4gbRAM Win 7x86
Proupin
Hi kilaD, I feel like home now
kilaD
Welcome home :)
Hello
Elvissuperstar007
not work for 2008 (
kilaD
Check the first post, you must download guruware's objexporter
Hello
Mstudio
I don't understand these script , please explain all. Thanks.
kilaD
Mstudio wrote:I don't understand these script , please explain all. Thanks.
check out this video:
http://www.refractivesoftware.com/forum ... =27&t=1613
Hello
buggy
I managed to get the script installed and after I click on the button to run it in Max, the dialog insists that I select an existing project when I hit render. I can click "New" and type in a new project name but I still get the warning. I tried to work around this by copying and renaming one of the demo projects, but then it couldn't find the obj export files so I browsed to the demo files and let it attempt to import these. I got an error in Octane and then Max froze up.
How do I resolve this issue?
On a side note, I tried downloading the Guruware OBJ exporter but the guruware download server is timing out. I found the 0.94b version zip on another site and downloaded it but when I copied it into my Max folder, I discovered that I already had the file there and that my file date is newer so I didn't overwrite it.
Thank you.
Win 8.1 | 2x GTX780 6GB RAM + 1x GTX 660 | Intel i7 | 16GB RAM | 3DS Max 2011
buggy
Okay, I notice that I if I click the Render button to export a still then the model comes into Octane. I was clicking Render Animation --perhaps this wasn't working because there are no animation keys in my Max file. I'll have to test that.
Running Max 2009
Return to “Autodesk 3Ds Max”
