Render speed Standalone <> 3dsmax
gueoct
How is render speed in 3dsmax related to the standalone version?
I am wondering if it depends on the standalone version, since you
have to install both of them...
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
FooZe
Yes, the 3ds max plugin uses the standalone edition core so the speed is the same for the actual render. Obviously the integration makes it a lot faster to use in terms of workflow.
Cheers
Chris.
Karba
3dsmax plugin uses only standalone licence. No matter what version of standalone you use.
gueoct
These were two opposite answers, right...????
Karba
gueoct wrote:These were two opposite answers, right...????
The last one.
gueoct
render speed is the same? What about the Kepler build?
Is there a difference between standalone and 3dsmax?
Karba
gueoct wrote:render speed is the same? What about the Kepler build?
Speed is the same.
Kepler is not supported fully. only 2.58f build supports kepler.
FooZe
Hi gueoct,
Sorry for the confusion...
I was under the impression it used the actual code installed by the standalone which as Karba pointed out is wrong, it has it's own copy of the rendering code.
This would by why the speed is the same etc since the rendering core is the same but it does not actually use the installed standalone code.
Sorry about that.
(Karba can correct me if i'm wrong :))
Cheers
Chris.
MaTtY631990
gueoct wrote:How is render speed in 3dsmax related to the standalone version?
I have seemed to see a difference in speed between the standalone and plugin.I just regularly like to lots of testing on these releases and the plugin seems to be nearly 2x slower than the standalone.
Karba
Can you show us some of your testings?
Images, times, and scenes?
Return to “Autodesk 3Ds Max”
