OctaneRender® for Maya® beta 2.58i [OBSOLETE]
Refractive Software®/Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012 and 2013 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 179€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
BUG FIXES SINCE LAST RELEASE:
  • Fixed the swatches color bug in LiveDB.
  • Fixed crash bug (when some specific objects were selected).
  • Fixed issue where default value of "Opacity" in new Diffuse Material was 0.0.
NEW FEATURES SINCE LAST RELEASE:
  • Added "Reload", "Edit" and "View" buttons to Octane image textures file control in Attribute Editor.
  • Started work on display textures in the ViewPort. No "mixed" textures and no procedural textures so far.
DOWNLOAD
Next version HERE.
Yours,
The OctaneRender™ Team.
Joss
Still 2 topics unclear:
1. what's with linux/macos versions?
2. is it possible to have an option for mirror ball/latlong env map?
As for crash - i just loaded Maya, switched to Octane in RG, and it's crashed. Maybe some random crash, tried to repeat this and no success. Going to send dumps if ill catch that crash once again.
Freelance CG TD, developer.
Slimshader
Joss wrote:is it possible to have an option for mirror ball/latlong env map?
+1
Slimshader
I found a bug with the image textures in the viewports.
During playback on the timeline, if the scale on image texture node is set to anything other than 1, the texture goes berzerk. The texture goes back to normal after you press stop and click in the viewport.
Otherwise it seems very stable this time round and the new buttons on the texture nodes are nice.
Joss wrote:1. what's with linux/macos versions?
Not at this stage.
Joss wrote:2. is it possible to have an option for mirror ball/latlong env map?
It is not supported by Octane SDK so far.
Slimshader wrote:I found a bug with the image textures in the viewports.
Thanks!
Will fix it.
A "quick fix" release will be ready soon (I think today), with this ViewPort textures scaling bug fixed and one LiveDB crash bug fixed (which Joss reported me to PM).
Next version HERE.
Return to “Autodesk Maya”
