OctaneRender® for Maya® beta 2.58c [OBSOLETE]
Refractive Software®/Otoy® is proud to announce the availability of a first version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012 and 2013 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 179€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
BUG FIXES SINCE LAST RELEASE:
  • Fixed one more crash bug.
  • Fixed bug when Attribute Editor "Inline" value not appeared immidiately after disconnecting of Octane Node from it.
  • Minor fixes...
NEW FEATURES SINCE LAST RELEASE:
  • Added "Opacity" attribute to Octane Light node.
  • Now it is able to render without SunSky node present in scene. In this case the black environment will be set as default.
  • Added "batch command render mode" support. It is experimental so far, so you may test it. See command line help by:
    <Maya install path>/bin/render -renderer octane -help
DOWNLOAD
Next version HERE.
Yours,
The OctaneRender™ Team.
Slimshader
It's crashing a lot when I try to get the octane lights to use IES lights.
The only time they worked for me was when I used the temp file that maya saved after a crash.
I'm trying to apply the IES from the attribute editor.
The opacity setting is fickle.
It sometimes stopped working and became visible again when I added an IES light.
Then the opacity would return as soon as I cleared the IES light field in the attribute editor.
Also, the IES lights still cast a shadow from the sun when invisible.
https://dl.dropbox.com/u/85554647/crashes.zip
Slimshader wrote:It's crashing a lot when I try to get the octane lights to use IES lights.
It sometimes stopped working when I added an IES light.
Thank you!
Now will fix that IES.;)
And how about previous bug?.. It must be OK now.
Slimshader
Yes, it's gone!
Slimshader wrote:Yes, it's gone!
Thanks to your dumps, I already see what is that problem - it only applies to Octane lights. I will fix it in a few hours.;)
Slimshader
Look at PM please.;)
Next version HERE.
Return to “Autodesk Maya”
