OctaneRender® for Maya® beta 2.58a [OBSOLETE]
Refractive Software®/Otoy® is proud to announce the availability of a first version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012 and 2013 / 32-bit & 64-bit on MS Windows operating systems.
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 179€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
DOWNLOAD
Next version HERE.
Yours,
The OctaneRender™ Team.
Slimshader
Rendering animations has been a problem.
Geometry and textures randomly disappear,
textures also swap places.
Material settings randomly change too.
Seems like the problems occur when the camera movement is broader.
The first 90 or so frames had slow movement so they rendered perfectly but once the camera started to move slightly faster the problems started.
Scenes load and save properly and it doesn't crash for me though.
Also, the same scene works 100% in standalone.
Slimshader wrote:Rendering animations has been a problem.
Can you please check if the problem still exists when you set the checkbox "Render in gray material" in "OctaneRender settings"?
Slimshader
With the render grey checked on, the problem seems to be gone.
When it's unchecked the textures are swapping randomly and geometry disappears.
Slimshader wrote:With the render grey checked on, the problem seems to be gone.
Thank you!
I'm working to reproduce it... Will fix when it will be catched.;)
Slimshader
Cool!
It's not a problem for me to share the scene file if it will help.
Slimshader wrote:Cool!
Thank you, it will be very helpful, as I'm not 3D-artist, and I do not have scenes complex enough to experiment. Can't reproduce so far on my simple scene...
Joss
Btw, little question: why is it default environment is white?
Freelance CG TD, developer.
Already catched that bug.
Fixed version will be in a few hours...
Joss wrote:Btw, little question: why is it default environment is white?
And what it should be? This is what in standalone is default:
The same in Maya plugin, FloatTexture by default, value 1.0...
How it is going with your reported issue about sluggish viewport when image textures are present?..
New fixed version HERE.
Return to “Autodesk Maya”
