C4D r11 camera problem with 11c
Daveyay
Hi
I have C4d r11 and using exporter 11c to build 2.58. All fine except when I export the camera from any model I get an error, the heading of which reads:
There was an error parsing the command-line arguments:
Couldn't find match for argument Argument: 0
I can post the full message if necessary
I've tried changing units and so on, but no luck. And the export is always successful without the camera. Any thoughts please?
Win7 x32 / QuadroFX 2700M / Core2 Duo /4GB
abstrax
Daveyay wrote:Hi
Could you post a screenshot of the C4D console window? It should show the command line that was used to open Octane.
Marcus
abstrax wrote:Thanks,
Marcus
oh man, are you back?
i can't believe :o
this is the best birthday present that i could have (one day before to tell the truth) :D
niuq.cam
:D Marcus? This is a joke? You're back in the team? Can we have some clarifications? I hope this is real. :)
Daveyay
Marcus,
Thank you. No need to post the screenshot, I checked it today and yes I had the wrong path set.
All fine now, Thanks!!
David
AndersBackman
I have the same problem. Octane works fine when exporting from C4D except when I check "Export Camera". When I try to export the camera, then Octane opens with this popup.
USAGE:
dummy program name [-m <string>] [-r <filename>] [-l <filename>] [-n
<filename>] [--imager-exposure <float>]
[--daylight-sundir-z <float>] [--daylight-sundir-y
<float>] [--daylight-sundir-x <float>]
[--cam-aperture <float>] [--cam-focaldepth <float>]
[--cam-fov <float>] [--cam-motion-up-z <float>]
[--cam-motion-up-y <float>] [--cam-motion-up-x
<float>] [--cam-motion-target-z <float>]
[--cam-motion-target-y <float>]
[--cam-motion-target-x <float>] [--cam-motion-pos-z
<float>] [--cam-motion-pos-y <float>]
[--cam-motion-pos-x <float>] [--cam-up-z <float>]
[--cam-up-y <float>] [--cam-up-x <float>]
[--cam-target-z <float>] [--cam-target-y <float>]
[--cam-target-x <float>] [--cam-pos-z <float>]
[--cam-pos-y <float>] [--cam-pos-x <float>] [-q] [-g
<int>] ... [-s <int>] [-o <filename>]
[--film-height <int>] [--film-width <int>] [-e] [--]
[--version] [-h] <filename>
Where:
-m <string>, --mesh-node <string>
Name of meshnode to render
-r <filename>, --relink-meshnode <filename>
Name of OBJ mesh file to relink rendered meshnoded with
-l <filename>, --link-meshnode <filename>
Name of OBJ mesh file to link after startup
-n <filename>, --new <filename>
Create a new OCS project file from given command line arguments
Imager Exposure Amount
Daylight Sun Direction Vector Z Component
--daylight-sundir-y <float>
Daylight Sun Direction Vector Y Component
Daylight Sun Direction Vector X Component
Camera Aperture Radius
Camera Focal Depth
--cam-fov <float>
Camera FOV (degrees)
Camera Up Motion 2nd Vector Z Component
Camera Up Motion 2nd Vector Y Component
--cam-motion-up-x <float>
Camera Up Motion 2nd Vector X Component
Camera Target Motion 2nd Position Z Component
Camera Target Motion 2nd Position Y Component
Camera Target Motion 2nd Position X Component
--cam-motion-pos-z <float>
Camera Motion 2nd Position Z Component
Camera Motion 2nd Position Y Component
Camera Motion 2nd Position X Component
--cam-up-z <float>
Camera Up Vector Z Component
--cam-up-y <float>
Camera Up Vector Y Component
--cam-up-x <float>
Camera Up Vector X Component
Camera Target Position Z Component
Camera Target Position Y Component
Camera Target Position X Component
--cam-pos-z <float>
Camera Position Z Component
--cam-pos-y <float>
Camera Position Y Component
--cam-pos-x <float>
Camera Position X Component
-q, --quiet
Start Application without splash and minimized window
-g <int>, --gpu <int> (accepted multiple times)
add GPU device to use for rendering (0 = first)
-s <int>, --samples <int>
Maximum number of samples per pixel (maxsamples)
-o <filename>, --output-png <filename>
Output PNG imagefile when maxsamples is reached
--film-height <int>
Film height
--film-width <int>
Film width
-e, --exit
Close the application when rendering is done
--, --ignore_rest
Ignores the rest of the labeled arguments following this flag.
--version
Displays version information and exits.
-h, --help
Displays usage information and exits.
<filename>
.OCS Project scene file
Octane Render
The C4D console says this:
"C:\Program Files\Octane\octane.exe" -n "C:\Users\Anders\Desktop\OctaneTest\RaceBoat_02.ocs" -m RaceBoat_02 -l "C:\Users\Anders\Desktop\OctaneTest\RaceBoat_02.obj" --film-width 1280 --film-height 544 --cam-pos-x 42.350042 --cam-pos-y 206.99491 --cam-pos-z -156.65632 --cam-target-x -115.66944 --cam-target-y 115.64547 --cam-target-z 32.728856 --cam-up-x -1.0729283e-008 --cam-up-y 1 --cam-up-z -8.9523148e-009 --cam-fov 90 --cam-lensshift-right 0 --cam-lensshift-up -0
Can't see anything wrong with my paths.
Daveyay - what path set did you change?
face
The problem is the first parameter:
-n will create a new ocs-file
It should be like this:
octane.exe -m test.obj -r "G:\Octane\ProjectA\test.obj" --cam-up-x -0.228925 --cam-up-y 0.918097 --cam-up-z -0.323561 --cam-target-x 1.77636e-015 --cam-target-y -4.44089e-015 --cam-target-z 0 --cam-pos-x 10.6582 --cam-pos-y 7.96666 --cam-pos-z 15.0643 --cam-fov 53.638 --cam-aperture 1 --cam-focaldepth 5 --imager-exposure 1 "G:\Octane\ProjectA\test.ocs"
face
http://vimeo.com/user2509578
AndersBackman
Ok. So now I've gotten the exporter to spit this out (which seems to be about the same as you suggested):
"C:\Program Files\Octane\octane.exe" -m RaceBoat_02 -r "C:\Users\Anders\Desktop\OctaneTest\RaceBoat_02.obj" --cam-pos-x 42.350042 --cam-pos-y 206.99491 --cam-pos-z -156.65632 --cam-target-x -115.66944 --cam-target-y 115.64547 --cam-target-z 32.728856 --cam-up-x -1.0729283e-008 --cam-up-y 1 --cam-up-z -8.9523148e-009 --cam-fov 90 --cam-lensshift-right 0 --cam-lensshift-up -0 "C:\Users\Anders\Desktop\OctaneTest\RaceBoat_02.ocs"
Still the same error message when entering Octane though. Unless I deselect camera export.
face
The -m RaceBoat_02 should be -m RaceBoat_02.obj.
face
abstrax
Hi Anders and Face,
If the mesh node must be named like the OBJ file, then this is a recent change in Octane. I need to look at it tomorrow. -m should specify only the mesh node to render, which can be named anything. The C4D exporter always omitted the .obj suffix which was fine until now.
I think the problem is the parameter "--cam-lensshift-up -0". I guess, for some reason the command line parser of Octane reads "-0" as an argument and not as number/value.
You can try this by slightly changing the "Film Offset Y" in the C4D camera you are exporting. If it works, then this was the problem.
Marcus
