Direct Light / Diffuse in 3dsmax does not work?
A forum for discussion, development and support, including subforums for discussion for various plugins for octane render and 3d the relevant animation packages
marilu2011
Why " Direct Light / Diffuse " gets dark in 3dsmax? Octane independent in this option the same option was PathTracing.
roeland
It depends on if there is glass in the windows. In direct lighting/diffuse mode Octane will trace rays from the camera through glossy and specular materials until it finds a diffuse reflection. From then on it will only consider diffuse reflections and stop on glossy and specular materials. This way it avoids most fireflies while usually still having some global illumination.
In your scene all the light in the room is coming through glass, and because the indirect rays stop on specular materials it is not included in the rendering.
Roeland
Karba
marilu2011 wrote:Why " Direct Light / Diffuse " gets dark in 3dsmax? Octane independent in this option the same option was PathTracing.
You have to increase diffuse maxdepth from 2 to 8.
Return to “Plugin Discussion/Support”
