Mesh: Failed To Allocate GPU Mesh Object :-( I can't close
JackMcRip
I can't close the Message:Mesh. Failed To Allocate GPU Mesh Object.
Octane hangs.
When I close the window, the window comes directly again.
I use the C4D-Exporter to load the scene to Octane.
I should reduce my scene. I know.
But hangs is bad.
Or can it be, This is only because I have many Objects in my scene.
And the window comes for every new object ?
C4D + ZBrush User
Use AMD Phenom 9850, GeForce 8600 256MB, 8GB
geort45
Try with half the objects, if the error doesn't come then try with the other half. If the error comes up, repeat until you find the responsible object. If the error doesn't come up then maybe it's the amount of polys and/or objects
SysSpecs: dual xeon [email protected], 10GB RAM, GTX 470, win7 x64. nvidia drivers 257.21
