Small BUG with Octane Camera Creation!!
nildoe
@Karba
When creating a Oct Camera, i notice that the TARGET does not get properly named, its Missing a dot before the "target" word, this makes renaming the camera a bit of a hassle because when u rename the camera, its Target does not get updated like the regular max camera. I tried manually adding the DOT and renaming, if i do this Oct Cam behaves like it should.
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
mbetke
I also had problems with the Octane camera and nothing happened in the viewport as I changed th FOV.
I had to use a common 3dsmax camera.
PURE3D Visualisierungen
Karba
nildoe wrote:@Karba
Nildo
Fixed, wait for a new release.
Karba
mbetke wrote:I also had problems with the Octane camera and nothing happened in the viewport as I changed th FOV.
What do you mean?
Just checked. Viewport reacts on FOV.
petermax
Didn't notice any issues with using a vray camera? What are the differences between using say a vray camera and octane camera?
Win 7 64 | 3 x GTX 580 | i7 950 | 24GB
Karba
petermax wrote:Didn't notice any issues with using a vray camera? What are the differences between using say a vray camera and octane camera?
You can control exposure and some other settings via octane camera.
nildoe
Great Thx alot Karba! :)
petermax
Ok I see, so you can override the default ones and have different cameras with different settings.
Return to “Autodesk 3Ds Max”
