What is the correct way to make glass surfaces modeling wise
nildoe
So the title says it all, i'd like to know if u guys actually make the glass on window for example to be/have 3 or 6 mm of thickness (or whatever) or do you just put a single plane in?!
I've putting a single plane when using vray and other renderers but im not so sure about Octane being unbiased and all :).
any response, much appreciated.
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
mbetke
Depends how much the glas swill be in focus.
Usually people tend to use only a single sided plane for basic reflection.
More computing intensive and realistic is a box (or two planes placed behind) which gives you a nice "shifted reflection" effect.
You also can use a very small bumpmap for the glass because the surface is never 100% even.
Below I used the box method with a very slight bumpmap for the shop windows. The shop interiours are just a texture placed behind my glass.
Glas Setup
Glas Setup
PURE3D Visualisierungen
nildoe
thx for that info mbetke! it helps alot :).
Nildo
Return to “Autodesk 3Ds Max”
