big problems with dof
xtrm3d
i seem to be doing fine with animation and material
but i really have a big problem with the dof
i really need to be able to control it on a frame per frame basis
i do not plan animation but a multi pose/angle shooting
any way to have a target object in maya that octane would use for the dof point of interest/autofocus ?
an example of what i get :-(
and here is what i would like to do ( if possible )
assuming that i want the body of kaneda to always be in focus
have a locator in maya that i can key for each frame , so that octane know what to use as a center for my dof
do that make sense ?
is that possible ?
pleeeeaase :-)
xtrm3d
ok
that official !!!
i am a DONKEY !! :-)
found that the aim camera is working in maya ..and i am now able to focus to certain part across my diferent frame ( example here the face )
but still ...
how can i control my lens aperture radius from frame to frame ?
xtrm3d
Could anyone give some insight ?
Monsieur bazooka maybe ?
Amplitude
I'm not a Maya user, but what I did in XSI was to rig the camera in order to have the right values (focus dist and aperture) exported to octane at each frame.
Win7 Pro x64 | GTX 770 2GB + GTS250 512Mb | Intel Xeon i7 4x 3.4ghz | 16 GB ECC Mem | Intel SSD 520 | Dell 27"
SOFTIMAGE l 2011 + OCTANE V1.20
bazuka
i hope ill be able to fix for a weekend the animated camera focal and lens...
cheers
Maya 2009 x64 & Maya 2011 x64
Windows 7 x64 & Windows XP x64
2x Quad Core Q6600, 8gb, Nvidia Gtx 260 & Gtx 460
xtrm3d
sound great !!
thank you for teh effort :-)
Doodle_Monkey
I've been able to accomplish DOF changes from frame to frame by creating a measurement tool (in maya it creates two locators and outputs the distance between) and parenting both ends to the aim and camera. Using the Hierarchy graph I found the output value and then fed the distance output of the distance tool into the DOF field on the cameras settings. I thought I was pretty clever, but maybe there is a better way. The end result was that I was able to animate the camera position and aim position interactively changing the distance value and therefore the DOF value from frame to frame. I've posted some videos on youtube of my experiments. One video in particular demonstrates this:
[youtube]http://www.youtube.com/watch?v=sjFFW5_-JZg&list=UUipORjqvU8HlwziwM6ST7Mw&feature=plcp[/youtube]
It's very short, but you get point.
Att3ro
Doodle_Monkey wrote:...in maya it creates two locators and outputs the distance between...
I would be very happy if you showed how you did it, cause I don't really understand how you manage to make it work.
Thanks in advance,
Att3ro
RickToxik
I've made a script here to control the DOF, if you want it:
http://render.otoy.com/forum/viewtopic.php?f=28&t=23455
Return to “Autodesk Maya”
