How to install the modo plugin
zero
How to install the modo plugin :?:
pixelrush
Apparently the instructions are included in the zip.
Perhaps this older post is helpful for Modo 601
Pacific88 wrote:i installed plug-in in 6 version and it seems like works fine. just had experience from another plug-in for modo. my installation was next.
copy all files like in manual comes..
then copy two files *.png and *.cfg file to config folder.
after this run modo goto file menu and in bottom find load config.. locate that cfg file and open it..
after this you can access menu render.. you need just to pin tab somewhere.. to pin choose menu group click plus button and from menu choose utilites and modotooctane
Octane v1.55
MartinBrinks
I tried following the instructions by Pacific88, and it installed fine - but exporting scenes to Octane has so far failed. Looking forward to the official plugin i finished!
jagger
I tried this in 701 and doesnt work. Any idea?
intel i7 3770k // 2 x Evga Titan Superclocked 6gb Vram // 16gb RAM
http://www.octavioalonso.com
Return to “Foundry Modo”
