Cards again
kivig
Nvidia 295 and 470 seems to be close in specs and price, except 295 has more mem. Which should perform better? Should there be big difference with 480?
Thanks!
It'd be great to put together performance table for everyone to see :)
http://www.visnevskis.com
Vista64/Ubuntu, GTX470/580
radiance
the GTX470 will be the best.
it has more memory and should be at least as fast and probably faster in the upcoming optimized builds.
Radiance
kivig
radiance wrote:the GTX470 will be the best.
Radiance
More memory? That's why i ask. According to NVidia:
GTX470 is 1280MB and 448 cores
GTX295 1792MB and 480 cores (+higher mem bandwidth/fillrate)
There must be something I don't know though...
Amplitude
in fact the gtx295 has two gpu on one card as you may know , so it has 2x 896mb memory and this doesn't add up as the memory is not shared between gpu's , the data is replicated. (and its true when you have several cards as well).
Win7 Pro x64 | GTX 770 2GB + GTS250 512Mb | Intel Xeon i7 4x 3.4ghz | 16 GB ECC Mem | Intel SSD 520 | Dell 27"
SOFTIMAGE l 2011 + OCTANE V1.20
kivig
Amplitude wrote:in fact the gtx295 has two gpu on one card as you may know , so it has 2x 896mb memory and this doesn't add up as the memory is not shared between gpu's , the data is replicated. (and its true when you have several cards as well).
Didn't know the memory is not shared. Thanks!
