I am using Maya 2010 on MAX OSX and I saw some comments that there might have been a new rewrite of the plugin so that one could find the binary path... I downloaded the latest one I believe... am I doing this correctly....
On the Octane Render BINary Path: /Applications/OctaneRender 1.022 beta2.2/Contents/MacOS/octane
Project path: /Users/peta/Documents/OCTANE_PROJECTS
Project Name: TEST
I get no error in the script menu... but octane does not launch:
The script window says...
/Applications/OctaneRender 1.022 beta2.2/Contents/MacOS/octane -n "/Users/peta/DocumentsOctaneTest_MB.ocs" -m OctaneTest_MB.obj -l "/Users/peta/DocumentsOctaneTest_MB.obj" --cam-pos-x 28 --cam-pos-y 21 --cam-pos-z 28 --cam-target-x 1.776356839e-14 --cam-target-y -1.421085472e-14 --cam-target-z -7.105427358e-15
MacOSX Script
- p3taoctane
- p3taoctane
/Applications/octane.app/Contents/MacOS/octane -n "/Users/peta/DocumentsOctaneTest_MB.ocs" -m OctaneTest_MB.obj -l "/Users/peta/DocumentsOctaneTest_MB.obj" --cam-pos-x 28 --cam-pos-y 21 --cam-pos-z 28 --cam-target-x 1.776356839e-14 --cam-target-y -1.421085472e-14 --cam-target-z -7.105427358e-15
Tried the path it said on the forum too and this is the repsonse
Put the script into :
/Users/Shared/Autodesk/maya/scripts
- p3taoctane
tried in maya 2011 as well:
/Applications/OctaneRender 1.022 beta2.2.app/Contents/MacOS/octane -n "/Users/peta/Documents/TESTII.ocs" -m TESTII.obj -l "/Users/peta/Documents/TESTII.obj" --cam-pos-x 28 --cam-pos-y 21 --cam-pos-z 28 --cam-target-x 1.776356839e-14 --cam-target-y -1.421085472e-14 --cam-target-z -7.105427358e-15
Same thing... no error just no launch
as i remember there is a probl with maya osx and selecting the octane executable, my friend cgbeige found the solution:
ok - just had a chance to try again. The script works only after I enter the path to the application manually because of two problems with the Mac version of Maya 2011 (it's a Qt problem): If you use OS-native dialogs, like I do, you can pick Octane.app but not the binary. If you use the Maya dialogs, it lets you go inside Octane.app but not select the binary. Yes, Maya 2011 is a train wreck.
So, in order for the script to work, I have to manually enter the path every time (u can save the path from script menu). So please add the path automatically to the script:
That's where the binary is and I don't think anyone's going to move it so I'd even say that having the option is overkill.
try and let me know
try and let me know
Maya 2009 x64 & Maya 2011 x64
Windows 7 x64 & Windows XP x64
2x Quad Core Q6600, 8gb, Nvidia Gtx 260 & Gtx 460
- p3taoctane
Thanks for the weekend reply. What dedication.
Still getting this message in the script editor
But no error
It writes the OBJ files out in the correct location but octane is not launching.
I even changed the name of octane beta xxx to just octane to see if that was it... no different.
Plugins can be so tricky when Autodesk changes the version they often break plugins that used o work so well.
Does it make any difference if I try it in 2010 or even 2009... should I try?
Thanks as always
/Applications/octane.app/Contents/MacOS/octane -n "/Users/peta/Documents/OCTANE_PROJECTStest.ocs" -m test.obj -l "/Users/peta/Documents/OCTANE_PROJECTStest.obj" --cam-pos-x 28 --cam-pos-y 21 --cam-pos-z 28 --cam-target-x 1.776356839e-14 --cam-target-y -1.421085472e-14 --cam-target-z -7.105427358e-15 --film-width 512 --film-height 256
But no error
Thanks as always
Plugins runing most, when they make to run with a earlyer version, in a newer one.p3taoctane wrote:Plugins can be so tricky when Autodesk changes the version they often break plugins that used o work so well.
I wrote mine with the sdk for XSI 6.5 and it runs from 6-2011...
It´s also a philosophy how to write a plugin.
face
http://vimeo.com/user2509578
hm well can u try to find the path to executable octane, maybe copy the path from shortcut from desktop or something, coz if nothing happen when u hit render and u get only the obj then the path for octane is not good, i wish i could help u more but im not into osx...
- p3taoctane
Not a big deal ... reckon we will figure it out sometime....
I copied the app to / and was able to "open /octane.app" in a shell window:
peter-allens-macbook-pro:/ peta$ open octane.app
and it launched right up so it is executable from a window with a path of /
so one would think that your script could find it if I pointed there...
But I still get...
so something else is amuck.... I will keep trying and mayeb another user may see something we are both missing.
here is something to ponder if i type Taranaki in there and nothing else.. I still do not get an error message...
Taranaki -n "/Users/peta/Documents/OCTANE_PROJECTStest.ocs" -m test.obj -l "/Users/peta/Documents/OCTANE_PROJECTStest.obj" --cam-pos-x 28 --cam-pos-y 21 --cam-pos-z 28 --cam-target-x 1.776356839e-14 --cam-target-y -1.421085472e-14 --cam-target-z -7.105427358e-15 --film-width 512 --film-height 256
Almost like the part of the script that is supposed to launch the app... is not being called out regardless of where you tell it to go... does that make any sense? Like its trying to find the binary in the path you give it but not launch it??? Good Luck.
Peter
But I still get...
Peter
