Hi all,
I am kind of lost here- I checked several threads but still can not find an answer...
I have a GTX 275 at the moment and would like to buy in addition GTX 470 (or even GTX480). What I do not know is:
1. Do I absolutely need to connect the two cards using a SLI connector or no connection is needed?
2. Can I connect two different cards (GTX 275 and GTX470) via SLI connector?
Thanks a lot.
How does multi GPU work?
Windows 7 64bit| Intel 3930K| 2x GTX 460 @700MHz 2048MB| 12GB RAM
You must not connect GPUs with SLI, if you want to use a CUDA application, Octane.julianb wrote:Hi all,
Thanks a lot.
Win7 64 | 2x XEON | 12GB | 8x GTX580
Thank you for your response, YoonKyung
So what- just insert the two different video cards in the PCI-E slots on the motherboard and adjust Octane's settings?
Is that it?
Cheers.
Is that it?
Cheers.
I remember seeing one of the post saying Octane can access different types of GPU. So yeah I think you are good to go.julianb wrote:Thank you for your response, YoonKyung
Is that it?
Cheers.
Dual Lindenhurst single core Xeon 3.6Ghz with Hyperthreads, 8GB DDR-2 ECC, Geforce GTX 260
Dual Xeon 5680 3.2Ghz with Hyperthreads, 24GB DDR-3 ECC, Quadro 4800 & GTX 480
Yup, dont connect them in SLI. NMake sure that physx is enabled in the nvidia control panel and setup the mult-gpu in the device manager of octane. Pretty easy.
System 1: EVGA gtx470 1280Mb and MSI gtx470 1280 in Cubix Xpander for Octane, AMD 945, 4Gb Ram
All systems are at stock speeds and settings.
make sure that physx IS NOT enabledhavensole wrote:Yup, dont connect them in SLI. NMake sure that physx is enabled in the nvidia control panel and setup the mult-gpu in the device manager of octane. Pretty easy.
little typo there havensole.
Radiance
i'm sorry Radiance but I had the case yesterday when I installed my second gpu:
if PhysX is NOT enabled, Octane doesn't NOT see the second gpu!
I went to a complete drivers reinstall before understanding that the PhysX setting was causing the issue.
Is it a bug?
Is it a bug?
Win7 Pro x64 | GTX 770 2GB + GTS250 512Mb | Intel Xeon i7 4x 3.4ghz | 16 GB ECC Mem | Intel SSD 520 | Dell 27"
SOFTIMAGE l 2011 + OCTANE V1.20
that's very strange as here it's the inverse.Amplitude wrote:i'm sorry Radiance but I had the case yesterday when I installed my second gpu:
Is it a bug?
if we enable physx on our multi-gpu machines here, the 2nd card is invisible... ?!
Radiance
I believe you, very strange that the situation can be inversed depending on the rig you use.
My board has an i975X chipset and SLI is not supported, don't know if it helps...
Drivers: Nvidia dev 197.13 + Cuda toolkit
Thanks for the replies, guys...
As to the physx settings- I will try both ways and see what works and what not.
Cheers.
Cheers.
