Whats going on here?
daadaa
Whats going on here? it looks like the mesh isnt welded.... maybe an export problem?
its weird cus some of it is smooth but some isnt.... also ive played around with the smoothing, doesnt seem to help :(
havensole
Can you tell us what 3d host app you used to make this?
System 1: EVGA gtx470 1280Mb and MSI gtx470 1280 in Cubix Xpander for Octane, AMD 945, 4Gb Ram
All systems are at stock speeds and settings.
daadaa
3D studio max. 2010
radiance
I thin you're scale is much too big. octane expects meters. (use obj import prefs panel to adjust)
Also i don't have a clue what it should look like and what export settings you used so any information and screenshots about those could also help...
Radiance
Amplitude
wow, this is kind of artsy :D
Win7 Pro x64 | GTX 770 2GB + GTS250 512Mb | Intel Xeon i7 4x 3.4ghz | 16 GB ECC Mem | Intel SSD 520 | Dell 27"
SOFTIMAGE l 2011 + OCTANE V1.20
daadaa
The car is modelled in meters, its physically correct with a 1.8m manakin.
this is what its suppose to look like... rendered in mental ray
[youtube]http://www.youtube.com/watch?v=M1QdkqTUfFg&feature=email[/youtube]
and heres the export settings. ive tried exporting in tris quads and polys, it doesnt seem to make a bit of difference. How ever, it does seem to work if i export an ultra high poly model.
Da
daadaa
changing scale "helps"... but doesnt solve the problem.
Here, u see the rims are fine, but the rest of the body is still weird :S
radiance
can you just try enabling the 'smooth' bool node on the yellow material in octane ?
Radiance
daadaa
ive tried enabling/disable on the smooth bool for the material... no change which leads me to believe its a problem with the model..... so ive imported the obj file back into max and it appears to be a problem with the "display iso lines only" option within max's subd option.
i would tell u how my theory went......but now max keeps crashing when exporting >_<
daadaa
Right.... ended up using max 2011 and that exported fine.... but problem exists within octane.
heres it in octane:
To check its not a problem with the model, ive imported it back into max:
incase it helps, heres the obj file if anyone want to have a look.
http://rapidshare.com/files/392182957/S ... y.obj.html
