Octane Sketchup Exporter - 1025-02
TIG
Here's v02 of the Exporter
Octane_1025-02.zip
(520.75 KiB) Downloaded 885 times
It addresses the recently reported issues with motion-blur in animation exports...
TIG
watchyour6
TIG,
Render Animation only produces the first two images.
The octane_anim.cmd file contains only two lines.
Win 7 x64 | 2x GTX460 2GB + GeForce 8600 GT 256MB | Quad 2.93GHz | 8GB
watchyour6
TIG,
My apologies.
In my test model, the second scene was a duplicate name, which was the cause of the problem.
TIG
So... it is now working OK ?
TIG
watchyour6
Just checked. It's working fine. Thanks!
Phantom107
This plugin is very useful. Thanks! :D
disturbed13
what one earth does that mean?
disturbed13
nvm
somehow i forgot to install octane first :oops:
TIG
Once it's installed browse to the exe file in the Exporter dialog and set it to use that.
Sketchup will remember the path across sessions etc on that PC...
TIG
smicha
TIG,
I have a problem with holes in mesh after exporting. The holes are (probably) due to small size of triangles (about 1mm wide). If so, is there a way to make exporter less sensitive to such small objects? I need such scaling in SU. Or something else is causing such holes?
Return to “SketchUp”
