65gto
xtrm3d
working on a new car ..
65 gto this time ..
should be pushing on the modeling side .. but did need a break and did play a little bit in octane :-)
Proupin
What you modeling with? maya, max, other? nurbs, polys? info man, info! :D
Fueye
i think, in most cases Lightwave + Maya ;-)
Win XP 64 / Zotac Geforce GTX470 / Q9550 2.83GHz / 8GB
Win XP 64 / PNY Geforce GTX470 / Q6700 2.67GHz / 8GB
xtrm3d
hummm ?
modelling ?
let see ...
maya , modo .. and a little bit of lw
SheepFactory
That is already looking sweet :)
I have the same problem. I model for a bit and then have to export to octane and spend an hour playing with it :D
http://www.alimation.ca
Win 7 64 bit
Gtx 275
i7 920
6gb ram
Driver version: 197.13
Amplitude
SheepFactory wrote: I have the same problem. I model for a bit and then have to export to octane and spend an hour playing with it :D
:lol: this is so true !
Win7 Pro x64 | GTX 770 2GB + GTS250 512Mb | Intel Xeon i7 4x 3.4ghz | 16 GB ECC Mem | Intel SSD 520 | Dell 27"
SOFTIMAGE l 2011 + OCTANE V1.20
xtrm3d
did some modeling today ...
and yes .. i also did some rendering too :-)
GeorgoSK
Very nice ;) ,
..and I know the tempting to render any progress in modeling :) before it was "finish model..then render"
Intel C4Q , 4G ram, GTX 285,
radiance
you can try to add a metallic fleck with a turbulence, and a 'clamp' texture.
no uv maps needed, it's a 3d procedural.
Radiance
xtrm3d
with metalic flake now .. ( even if i would remove them later ..as i am not so sure thy did have them in the 60's )
Return to “Works In Progress”
