OctaneRender® for 3ds max® v1.0 beta 2.58[TEST]
Karba
Refractive Software® is proud to announce the availability of a new version of OctaneRender® for 3ds max®: Version 1.0 beta 2.58.
The world's fastest and most feature-rich unbiased render engine that integrates completely into Autodesk® 3ds max®.
3ds max® Version Requirements
This release will only work with 3ds max® Versions 2010, 2011 & 2012 / 32bit & 64x / Base & Design on MS Windows operating systems.
This build contains first material preview implementation. Can be unstable.
OctaneRender® for 3ds max® implements all functionality of OctaneRender® standalone inside 3ds max®.
Any feature that the Standalone edition supports is supported by the 3ds max® plugin.
Note that this plugin product is built against OctaneRender® Standalone v1.0 beta 2.58, which does not include instancing and object motion/transform editing.
When OctaneRender® Standalone 2.6 is released during the next weeks, the plugin will be updated shortly thereafter to include the new functionality of 2.6.
However, due to the fact that the plugin is tightly integrated in 3ds max, and requires no file IO for changes to scene or object motion, moving objects, changing scene geometry and rendering animations is already MUCH faster than with the old 3ds max export script and file IO with the standalone version, so don't be dissapointed until you actually try it. You will notice rendering animations straight from within 3ds max® is very fast. (for example: what takes 5 minutes to export/import with file IO using exporters takes 20-30 seconds with the plugin product version)
Backburner is not supported properly yet. Don't use it. It will be fixed in next version.
To run OctaneRender® for 3ds max®, you need to also have an activated OctaneRender® Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the 3ds max plugin and use it without also owning an activated copy of OctaneRender® Standalone on your machine
HOW TO PURCHASE LICENSES
Go to our online shop here: http://www.refractivesoftware.com/shop/
If you do not own an OctaneRender® Standalone Edition License yet:
You can purchase both the OctaneRender® Standalone Edition and the OctaneRender® for 3ds max® Edition as a reduced price bundle, purchase the bundle priced at 179€
If you already own one or more OctaneRender® Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender® for 3ds max® v1.0 Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender® for 3ds max® licenses,
just like OctaneRender Standalone Edition packs.
DEMO VERSION AVAILABILITY
Currently there is no demo version available of the 3ds max® plugin product.
We will be providing one soon sometime in january after the christmas holidays.
INSTALLATION INSTRUCTIONS
At this moment there isn't automatic installation. You have to copy files to 3ds max manually.
Please read the installation text file included in the download ZIP file archive.
OCTANELIVE®
Just like OctaneRender® Standalone, The 3ds max® plugin product also needs an additional octanelive license and be activated on a machine.
This has to be done in the plugin interface panel in 3ds max, and is covered in the included PDF manual.
It can only be done after an OctaneRender® Standalone license is already activated on the machine in question.
NEW FEATURES SINCE LAST RELEASE:
  • IES texture support.
  • New material preview.
  • Option of camera and materials animation without geometry update.
  • Speeding up material preparation for animation.
    BUG FIXES SINCE LAST RELEASE:
  • Animation freezing in case of wrong texture pathes.
    DOWNLOAD
    We have 3 separate archives available for download, for Autodesk® 3ds max® 2010, 2011 and 2012.
    Each archive contains the manual and installation text file, and both 32bit and x64 versions of the plugin,
    so you only need to dowload one archive for your 3ds max® version from the following download links:
    3ds max® 2010: http://www.refractivesoftware.com/plugi ... a_2.58.zip (50MB ZIP File)
    3ds max® 2011: http://www.refractivesoftware.com/plugi ... a_2.58.zip (50MB ZIP File)
    3ds max® 2012: http://www.refractivesoftware.com/plugi ... a_2.58.zip (50MB ZIP File)
    We hope you enjoy using OctaneRender® for 3ds max® as much as we loved developing it :)
    Yours,
    The OctaneRender® Team.
pixelrush
Hmmmm, won't they need a stand alone 2.58 as well? :roll:
Octane v1.55
Karba
pixelrush wrote:Hmmmm, won't they need a stand alone 2.58 as well? :roll:
All included.
lixai
so if i don't have octane for max, i still have in this release octane standalone ?
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
afzznana
Finally.... I can see octaneRender material in material editor. Really helpful. Thanks so much guys!!! :D
t_3
All included.
hmmm...
The obvious is that which is never seen until someone expresses it simply
tehfailsafe
Quick note on the matieral preview, I notice a dramatic increase in my 1st card vram when opening the material editor. Is each material preview an octane preview window that gets loaded? Does this get "doubled" when I try to render a large scene? Say if material editor is using 500 mb of vram, system uses some, max uses another 100+ or so, that leaves me with very little vram on a 1.5gb card.
Or does it get cleared before trying a render / octane preview window?
windows 7 64 bit| GTX580 1.5Gb x2 | Intel 2600k @ 4.9 | 16gb ddr3 | 3ds max 2012
Karba
tehfailsafe wrote:Quick note on the matieral preview, I notice a dramatic increase in my 1st card vram when opening the material editor. Is each material preview an octane preview window that gets loaded? Does this get "doubled" when I try to render a large scene? Say if material editor is using 500 mb of vram, system uses some, max uses another 100+ or so, that leaves me with very little vram on a 1.5gb card.
We will check it.
Jaberwocky
Thanks Karba
I Will have a play with it.
mbetke
Do i understand right that I can now make a turntable animation without re-exporting the geometry every frame? This would be great. :D
PURE3D Visualisierungen
Return to “Autodesk 3Ds Max”
