help needed - test scenes for black geometry OBJ import
radiance
Hi all,
Some users have reported object materials loading as pure black on some materials.
Can someone please attach some reasonably small OBJ+MTL files here which exhibit the problem, as we cannot reproduce it with our testscenes ?
Radiance
MagnusL3D
Not sure if this helps but I've gotten black .OBJ's to when exporting from Houdini.
I solved this in Houdini by assigning correct normals to the object, the black objects had no normals assigned to them, essentially 0,0,0 on the vertex's.
/M
livuxman
One of the problems, if not unique, is with geometry that does not contain normals.
In the previous version the normals was generated correctly by octane, but now appears black.
Attached is a basic example, that imported with the previous version appears correctly and now appears black.
Cheers
test.zip
(7.5 KiB) Downloaded 279 times
LiVux 64bit | Geforce GTX260 Core 216 and GTX470 | i7 860 | 8Gb | Drivers 275.09.07 | Cuda 4.0.17
Nostromo
Thanks for the sample, I'll try it right away.
Nostromo
Extremely strange.. on my machine it displays fine, just like previous version.
Are you using the default obj import settings and just starting octane, import mesh and display ?
/M
livuxman
Yes, I open the program, add the object and give it to render, do not play anything else.
I use the linux version, may have something to do.
Nostromo
Ok, thanks that is fixed. Was only for Mac/Linux.
