open GL issue?
homer
Hi Radience et all
I'm dying to try out this amazing program but get the error message below. I've run the CUDA testing app and everything seems fine there .. what am I doing wrong?
Chris H
Win XP 32 | Geforce 8800GTX | Quad 2.66GHz | 4GB
homer
Mods,
Apologies. I've just realised I've posted this in the wrong forum.
Chris H.
Home: Win XP 32 (SP3) | Geforce 8800GTX | Quad 2.66GHz | 4GB
Work: Win XP 32 (SP3) | Geforce NVS440 | Pentium D 3.40GHz | 1GB
radiance
have you installed the correct drivers as outlined in the readme that comes with the demo version ?
Radiance
homer
Hi Radiance,
I'm sure I've followed everything in the readme. Downloaded the CUDA testing app (s/s below) and everything seems fine there. All other drivers are up to date. Any suggestions?
Thanks in advance.
Chris H
pixelrush
You are using the nvidia 190.38 driver? and Octane8000.exe?
btw is that XPsp3?
Octane v1.55
homer
Hi Pixelrush
Thanks for the prompt response.
Unfortunately the answer is yes to all your questions.
Chris H
pixelrush
Well that's frustrating and disappointing.
I'm not sure what's wrong there.
I'm not an expert only a user like you.
I found a utility application to test openGL.
http://www.realtech-vr.com/glview/index.html
If you want to corner the issue you could try using that to see if there is anything obviously wrong.
Other than that is the card an unusual brand perhaps?
Octane v1.55
radiance
can you show us a screenshot of your driver versions ?
Radiance
Tim Ellis
I'm running the same video card but on Win XP pro x64 SP2. Not had this Open gl error at all.
Driver details:-
NVIDIA System Information report created on: 01/18/2010 12:22:14
System name: TIM
[Display]
Processor:		Dual Core AMD Opteron(tm) Processor 275 (2200 MHz)
Operating System:	Microsoft Windows XP, 64-bit (Service Pack 2)
DirectX version:	9.0c
GPU processor:		GeForce 8800 GTX
Driver version:		190.38
Stream processors:	128
Core clock:		576 MHz
Shader clock:		1350 MHz
Memory clock:		900 MHz (1800 MHz data rate)
Memory interface:	384-bit
Memory:			768 MB
Video BIOS version:	60.80.06.00.01
IRQ:			19
Bus:			PCI Express x16
[Components]
nvCplUIR.dll		2.7.130.16		NVIDIA Control Panel
nvCpl.cpl		2.7.170.15		NVIDIA Control Panel Applet
nvExpBar.dll		1.5.620.03		NVIDIA Control Panel
nvCplUI.exe		2.7.170.15		NVIDIA Control Panel
nvWSSR.dll		6.14.11.9038		NVIDIA Workstation Server
nvWSS.dll		6.14.11.9038		NVIDIA Workstation Server
nvViTvSR.dll		6.14.11.9038		NVIDIA Video and TV Server
nvViTvS.dll		6.14.11.9038		NVIDIA Video and TV Server
nvMoblSR.dll		6.14.11.9038		NVIDIA Mobile Server
nvMoblS.dll		6.14.11.9038		NVIDIA Mobile Server
nvDispSR.dll		6.14.11.9038		NVIDIA Display Server
NVMCTRAY.DLL		6.14.11.9038		NVIDIA Media Center Library
NVOGLNT.DLL		6.14.11.9038		NVIDIA Compatible OpenGL ICD
nvDispS.dll		6.14.11.9038		NVIDIA Display Server
NVCPL.DLL		6.14.11.9038		NVIDIA Compatible Windows 2000 Display driver, Version 190.38
NV4_MINI.SYS		6.14.11.9038		NVIDIA Compatible Windows 2000 Miniport Driver, Version 190.38
NV4_DISP.DLL		6.14.11.9038		NVIDIA Compatible Windows 2000 Display driver, Version 190.38
PhysX		09.09.0814		NVIDIA PhysX
NVCUDA.DLL		6.14.11.9038		NVIDIA CUDA 2.3 driver
nvGameSR.dll		6.14.11.9038		NVIDIA 3D Settings Server
nvGameS.dll		6.14.11.9038		NVIDIA 3D Settings Server
Driver is official release from Nvidia for x64 Win.
Hope this helps.
Tim.
Win XP Pro x64 SP2 - 2x Dual core AMD Opteron 275 @ 2.20GHz - 8GBRAM - GForce 8800 GTX
Tim Ellis
Have just checked latest driver available for GForce 8800 GTX is 195.62, which I haven't yet installed or tested with Octane.
190.38 doesn't report opengl error message though.
Tim.
