GTX 280 on PCIe x8???
gramiyoe
Hello,
i have one question. Has anybody tried to run Octane on GTX 260 + on motherboard supported only PCIe x8 only? (should be x16).
Program is starting up, i can load objects but if i try to render it crashes.
Sorry for my bad english :P
My spec. WIN VISTA ULTIMATE x64 / GFX280 / 4GB RAM / Core 2 Duo e6600 / ASUS P5W DH Deluxe
YoonKyung
gramiyoe wrote:Hello,
I think, the reason of crash is not came from PCIe x8.
Did you install proper CUDA driver, version 3.0?
Win7 64 | 2x XEON | 12GB | 8x GTX580
gramiyoe
What exactly i have to install? CUDA toolkit only from this link http://www.nvidia.com/object/thankyou.h ... win_32.exe ?????
radiance
If you're using windows, just install the latest drivers from the nvidia website for your operating system and GPU type.
Radiance
gramiyoe
I've try all that things.... and nothing. Drivers are latest and working fine. I'm doing everything like in first video. Import objects, then click on it to render. Program seems to calculating something, but i can't see objects there like on video. I try to set up the view than program crashes.
Maybe this IS cause PCIe x8???
radiance
gramiyoe wrote:I've try all that things.... and nothing. Drivers are latest and working fine. I'm doing everything like in first video. Import objects, then click on it to render. Program seems to calculating something, but i can't see objects there like on video. I try to set up the view than program crashes.
no, a 8x or 16x slot makes no difference, it's just a little bit slower.
i recommend using the free tool 'driver sweeper', google for it, remove all nvidia drivers,
and reinstall the latest WHQL drivers from the main nvidia download site.
Radiance
gramiyoe
I used drive sweeper, install latest whql drivers from nvidia, and problem is the same :( Even tried to load diferrent .obj objects...
If anyone have any idea...
I bought this GTX 280 especially for Octane.... there must be some way...
radiance
do the demo suite scenes work ?
they are a separate zip file that you can download on the demo downloads page.
Radiance
gramiyoe
No.... i can load them, but after few seconds i click render program crashes...
radiance
gramiyoe wrote:No.... i can load them, but after few seconds i click render program crashes...
can you explain, in details please.
if you load the benchmark scene in the demosuite archives, via File -> Open, the load the benchmark OCS project file.
once it's loaded you click on the mesh node.
do you see anything rendered or does it just crash when you click on the node ?
if this is the case, you're drivers are screwed up.
in that case we can't help you any further, if you sweeped your drivers and installed the latest ones,
and it still does'nt work, there's something wrong with your windows installation or such...
does the card work ? have you tried running a video game on it ?
Radiance
