Changing textures/images
candide
Hello,
Currently changing textures/images (for example HDRI textures for the environment) involves switching the texture type to something else and then back to "image". Can we get a button that summons the file dialog dialog directly if the type is image already? Thanks! :D
PhilBo
Agreed and noted.
Thanks.
Win7 64| Two GTX 470s | Phenom II 920 | 8 GB
Win7 32| GTX 260 | Athlon X2 5000+ BE | 2 GB
Sam
Also when rendering is done (for example you set MAX rays to 100 and finish the render) when you change the HDRI or any parameter. The render doesn't refresh.
You need to change the MAX rays for the render to get back to 0 samples.
Kinda annoying :lol:
enricocerica
Sam wrote:Also when rendering is done (for example you set MAX rays to 100 and finish the render) when you change the HDRI or any parameter. The render doesn't refresh.
You could use the restart button, near the pause one it restarts the rendering.
http://www.myline.be
Sam
Yes but sometimes the restart button crash Octane but maybe its because I only used on my 8600M GT from my laptop.
