Hello: I'm new here + First Octane Test.
Goesi
Hello Hello.
First of all I want to say "Hello!". I'm glad to be here.
This is my first post here on the forum after I purchased Octane Render.
So I just want to show you my first Tests. I hope I will get some time to update the post regularly.
Enjoy...
t_3
welcome! glad to have you with us :)
your first "test" already looks fantastic! :shock: imo it is not easy to acquire such a realistic look with a "simple" setup like that; has an absolute photographic look to it (colors, lighting, framing, dof) - did you do postwork on this?
ps: i even don't mind the noise - well a little ;) it could be less, but personally i won't burn them to be completely noise-free; imo adds some realism to it...
Goesi
Thank you, thank you :)
Hmmm, yes its really noisy. I've just render each image for about 30 mins.
Once i've finished this project I will render it a bit longer ;)
I think I have to buy a really good GPU.
At the moment I'm not really familiar with Octane. So I hope I can push the Quality a bit in the final renderings.
And, yes. I did postwork on this. Just a little colour-correction.
Sportler
Wow, looks highly photorealistic :D
A pity the background doesn't quite match the color temperature :/ It also looks like light is coming from another direction on the mountains.
GPU: 1x Nvidia RTX 3080 Ti
RAM: 64GB DDR4 3200MHz
CPU: 5950x
Goesi
Hey Sportler. Thank you for the feedback.
Yeah I know. I haven't found a good snowy Mountain-Hdri. I'm still searching ;)
... and its far away from finish.
I hope I will find a solution for nice shadows on Hdri lighting. It's a bit tricky in Octane, hu?
In the next days I'll play a bit around to ger familiar with Octane.
Marcus
Goesi
Ok. Here some further tests.
Enjoy...
said
hello Goesi,
your images looks really good i like it :)
you dont used path tracing right?
can u tell me something about the rendertime?
how many light source do you have or did you used only daylight?
good work!
greeting
said
Windows 7 64bit
i7 2600k 3,5 GHz
Asus GTX 570
16GB DDR 3
Archicad 15____Cinema 4D R13______3Ds Max 2011_____Octane for 3Ds Max
Goesi
Thank you!
I used path tracing. Does it look like direct lighting? :|
Rendertimes were 1 hour per render on a GTX 560.
(Yes, I will buy a faster one soon ;) )
And I used a daylight and some mesh emitters on the standing light and on the ceiling light.
Marcus
said
ah okay no i just want to know because you can have the same result with direct light :)
but it looks really great i like your images
said
Windows 7 64bit
i7 2600k 3,5 GHz
Asus GTX 570
16GB DDR 3
Goesi
You mean: Direct Light / GI Mode: Diffuse?
Return to “Works In Progress”
