Circular lines in render with geforce 9800GT
- scarecrow2k6
Have you tried turning off "Smooth"? That's probably what causing that weird circular thingy.
- scarecrow2k6
After you have imported your OBJ file, click on the "Material Picker" which is located on top and it looks like a "Black ball with a dropper". Click on the object with circular issue and it will take you to its material properties on the right side of the Viewport. There you will find stuff like Diffuse, Transition, Bump....at the end there is Smooth with a pink dot on its left side. Uncheck Enable. I apologize if I made it sound too complicated.mynameis wrote:I have read about this 'smooth' but where do I turn it off? during import/export or in octane? thanks for the quick reply
What does it look like when you apply a brand new completely standard diffuse material to the object?
My guesses without seeing that are: a) still something weird in the material perhaps due to the obj deffinition. b) some sort of face intereference c) something to do with normals or smoothing maybe
Win8.1 | Quadro + Titan | Xeons & Corei7 | 12 GB etc
This looks like the familiar old scaling issue:
http://www.refractivesoftware.com/forum ... f=23&t=361
Ubuntu 9.10 x64 | GTS 240 | 260.19.44 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb| Blender 2.56a/latest Yoyoz plugin
WinXP32 | GTS 240 | 266.58 drivers | 3.0 Toolkit | Dual-Core 2.4 GHz | 4Gb | Blender 2.56a/latest Yoyoz plugin
