Renderings 2012
acestudio
That's my latest renderings with octane. C&C very welcome.
Done with 3dsmax, post processing in photoshop
Modeling with blender
Done with 3dsmax, sketchup, post processing in photoshop
Alessandro NC
Brasil
Core 17 [email protected] ghz | 16 gb ram | Windows 7 | Geforce GTX 580 1536
t_3
nice set of images ;) the first one i like best. the last one is also very cool, i' only reduce bumps by a good amount in this one...
The obvious is that which is never seen until someone expresses it simply
acestudio
t_3 wrote:nice set of images ;) the first one i like best. the last one is also very cool, i' only reduce bumps by a good amount in this one...
Thanks t_3 and well observed the problem with the bump on the walls. Actually I've seen this problem when the render was done in high resolution. This image has not been approved by the client and did not return to fix it.
Best regards
Alessandro NC
Brasil
said
wow great work my favorite is the last one very impressive very good work :o
why is the first one a bit noisy, can u tell me something about the rendertime and samples?
greeting
said
Windows 7 64bit
i7 2600k 3,5 GHz
Asus GTX 570
16GB DDR 3
Archicad 15____Cinema 4D R13______3Ds Max 2011_____Octane for 3Ds Max
acestudio
Hi said, I'm glad you like :)
Well, the first image was done in version 2.52 with 16.000 samples in pmc mode, but I interrupted to 8000 around and took about a half hour, this was just a test using an old project done with vray. I'll return to this scene soon and will post here.
Best regards
Alessandro NC
Brasil
said
hello again,
have u used a portal?
if not look at this link ;)
http://refractivesoftware.com/forum/vie ... =21&t=7210
maybe it helps you
greeting
said
Windows 7 64bit
i7 2600k 3,5 GHz
Asus GTX 570
16GB DDR 3
acestudio
Hey said,
In really in this scene (first) have not used, I agree that this coulda be the cause of the noise. in my new version I'll put.
Thanks for your advices :)
Greeting
Alex
Alessandro NC
Brasil
m_m_
Very beautiful.
Bye
"Il principio della scienza della pittura è il punto, il secondo è la linea, il terzo è la superficie, il quarto è il corpo che si veste di tal superficie"
Leonardo da Vinci
