Hallo.
Thanks to those who will give me a help.
How to map the texture so that it appears one side of a Sir Biss?
Yes: 1 Sir Biss
No: 10, 20, 30 etc. Sir Biss
I can not.
P.S.
Only Octane Standalone
Texture mapping
Tweak the scale parameter on the texture node and / or properly map your plane to the image before you export
cgmo.net
cgmo.net
Thank you.matej wrote:Tweak the scale parameter on the texture node and / or properly map your plane to the image before you export
There is no command to place an image on a surface only once?
Grazie.
Non esiste un comando per posizionare una immagine solo una volta su una superficie?
"Il principio della scienza della pittura è il punto, il secondo è la linea, il terzo è la superficie, il quarto è il corpo che si veste di tal superficie"
Leonardo da Vinci
Leonardo da Vinci
If you are referring to tiling of the texture, than you must take care of this yourself - as said, properly map the plane on the texture in your 3D application and / or adjust the scale of the texture in Octane.
cgmo.net
cgmo.net
O.K.matej wrote:If you are referring to tiling of the texture, than you must take care of this yourself - as said, properly map the plane on the texture in your 3D application and / or adjust the scale of the texture in Octane.
Grazie
Leonardo da Vinci
Leonardo da Vinci
