Hi guys,
Love your product, the idea and most of the functionality is great Apart from the following... I am having crashes very frequently opening .obj files that are not that heavy. If I get one that passes if you will the initial phase (pressing on the Mesh Node) and visualizing it, I will almost certainly get a crash when trying to add my own material or modify the existing ones.
It seems in all my ignorance that above 15mb or so it will almost allways happen. I am using the recommended drivers along with Windows 7, Nvidia 260, Asus striker...etc
If one could load a bigger scene for Archi stuff along with furniture etc I would buy a copy and give you free publicity...
Is it just me ?
Best
Cheeseburger
Stability
These problems are either due to wrong drivers, sometimes even with the latest drivers installed. (you need to use a sweeper tool to uninstall , then reinstall again)
Also, you should run the registry tweak to increase the watchdog timeout issue here:
http://www.refractivesoftware.com/forum ... f=21&t=824
we're also releasing a 2.1 update in a few days that will be more stable.
Radiance
Radiance
- cheeseburger
Thanks Radiance,
I'll try these to be going on with and get back to you...
