Portal light doesn't have any obvious effect (NOT WORK?)
rubbersoul
I made a very simple scene , with a big window and a plane for simulation of portal light (NORMAL FACING INWARD , no careless mistake I think ... :D )
Then I made a couple compared render , 1 of it was plugged w portal material , using PMC :
The other one plugged w a diffuse material (opacity=0) , it suppose to be totally transparent :
It's strange that , the result of these 2 rendering is 100% same . The portal light one suppose to be more full of brightness ... but It wasn't happened ...
I'ld be very appreciate for anyone who can give us any HELP of it !!!
face
Have you try to flip the normal direction?
face
http://vimeo.com/user2509578
rubbersoul
face wrote:Have you try to flip the normal direction?
face
Yes , I've tried the normal Inward/Outward ... still nothing happen . I can attach this .osc file for who interest to try this simple test .... Thanks
Portal.zip
(17.2 KiB) Downloaded 205 times
roeland
Using a portal will not alter the final rendered image in any way, but it makes Octane more efficient in rendering light that comes through the windows. If you render an interior with all light coming from an environment through a few small windows, the image should have less noise after rendering for the same amount of time.
Roeland
rubbersoul
roeland wrote:Using a portal will not alter the final rendered image in any way, but it makes Octane more efficient in rendering light that comes through the windows. If you render an interior with all light coming from an environment through a few small windows, the image should have less noise after rendering for the same amount of time.
Roeland
Thanks Roeland , It's very clear . Love Octane render anyway ! :)
