Animation - using batch exporter script from max
Cool. Can you try it next time with glossy material on the boxes?
n1k
n1k
Well im planing to do a 35mm footage track with an octane car moving or something down that road - in 3d space and some reflective shaders.
-these hyper simple tests serves as workflow optimizers, not eyecandy.
Amiga 1000 with 2mb memory card
I'm just interested what flickering will be like when using glossy mat.
There wont be any flicker if you let it cook long enough, alternativly you can use De:noise plugin for after effects to smooth potential noise logically.
However, speckles has nothing to do with noise so they fall through the analysis as they do not share the behaviours of noise.
Conclusion : wait till the speckles are gone in the compiled program for a steady image.
Ok. Tnx for info:)
héhé,
[gk] at last you're a licenced customer
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
- meleseDESIGN
- Contact:
Nice.
What is it for an script?
Will it automat the load->render->save process with Octane or do you still need to load every frame of the sequence manually?
XP 64-bit | ASUS MARS DUAL GTX285 4GB Limited Edition | DUAL XEON X5570 | 48GB DDR3 ECC Reg 1333MHz
