Octane and Performance Gtx590?
marilu2011
Hi, I use two Gtx560 Ti with 1 GB of memory each factory overclocked, if I trade for a Gtx590, performance increases? the problem is when I am rendering an interior scene and use the direct diffuse light (4), or pathtracing pmc, get a DERT full of noise takes the picture, I would like to speed up rendering.
Refracty
The 590 should be almost twice as fast as your 560 Ti.
http://www.refractivesoftware.com/forum ... f=9&t=7383
marilu2011
The tests were made ​​with only one card, I use two cards from Zotac Amp gtx560ti that has high frequency due to overclock at factory want to know if a card is a gtx590 outperform gtx560 you two plaques Amp? cAlguem tested here or use a Gtx590?
t_3
marilu2011 wrote:The tests were made ​​with only one card, I use two cards from Zotac Amp gtx560ti that has high frequency due to overclock at factory want to know if a card is a gtx590 outperform gtx560 you two plaques Amp? cAlguem tested here or use a Gtx590?
if you have two of them, just double the numbers. and if you scroll down a bit, you'll see that i have benched the 560ti at excatly the mhz that the zotac runs (950). it is just that way refracty already posted: one 590 at stock clock will deliver more than double the performance of two overclocked 560 tis (nearly 3 times, if the clock is slightly raised)...
The obvious is that which is never seen until someone expresses it simply
