Cinema 4D - OctaneX PR11/PR14 builds(Updated on 22.04.2022)
altestudio
Nice! :)
Ron
Hi Ahmet,
after a very long time of working on WIN I need to run Octane on a M1-Mac with current version of Monterey.
I installed standalone which is running fine. Only the plugin is not loaded in C4D R26. What am i dong wrong here?
Thanks and regards
Ron
Master: WIN 10 64bit, i7 4930 4,5 Ghz, 64 GB RAM, 1600 W PSU, 1 TB SSD, 14 TB RAID, 2 x RTX 3090
altestudio
Hey Beppe, any news on the release yet? How will I know when it's been released? Will it be announced in this thread or a different one?
Ron wrote:Hi Ahmet,
Thanks and regards
Ron
It requires min 26.107 and OSX 12.3. And M1 system. Disable rosetta for Cinema4D
altestudio wrote:Hey Beppe, any news on the release yet? How will I know when it's been released? Will it be announced in this thread or a different one?
It's available for M1 processors for now.
viewtopic.php?f=85&t=80247
altestudio
Thanks, I can see the colour management setting now but when I start the live viewer I get this error, any idea why?
Started logging on 19.08.22 10:33:45
Octane X Prime 2022.1 XB 3 (12000004)
VRAM used/free/max:0Kb/64Gb/64Gb Out-of-core used:0Kb RAM used:38.888Gb total:64Gb OpenGL free/total:0/0
Scene created in plugin version 11000100
Scene plugin version is older than version:2022.1-XB3-(R3)
Plugin will convert the parameters of displacement texture.
Animated attributes should be changed by manually!
FumeFx library initialisation error!
--------------------------- EXPORT LOG ---------------------------
Multi-threaded material conversion, thread count=8
Export materials time= 1.24 ms
Collect objects time= 0.175 ms
Mesh creation time = 15.042 ms.
Failed to build OCIO output transform: No OCIO config loaded
Api update time: 0.054 ms.
MB:0/0 ST/MOV:0/2 Nodes:18 Tris:1k DispTris:0 Hairs:0 Meshes:3
Textures Grey8/16:0/0 Rgb32/64:0/2
Export materials time= 0.555 ms
Collect objects time= 0.064 ms
Mesh creation time = 0.793 ms.
Api update time: 0.046 ms.
Export materials time= 0.548 ms
Collect objects time= 0.063 ms
Mesh creation time = 0.763 ms.
Api update time: 0.043 ms.
Export materials time= 0.566 ms
Collect objects time= 0.066 ms
Mesh creation time = 5.251 ms.
MB:0/0 ST/MOV:0/2 Nodes:17 Tris:1k DispTris:0 Hairs:0 Meshes:3
Export materials time= 0.087 ms
Collect objects time= 0.068 ms
Mesh creation time = 4.143 ms.
Api update time: 0.048 ms.
MB:0/0 ST/MOV:0/2 Nodes:15 Tris:1k DispTris:0 Hairs:0 Meshes:3
Export materials time= 0.089 ms
Collect objects time= 0.046 ms
Mesh creation time = 1.241 ms.
Api update time: 0.04 ms.
MB:0/0 ST/MOV:0/0 Nodes:11 Tris:2 DispTris:0 Hairs:0 Meshes:1
device 0: failed to initialize render thread 0x7fae7c054310
Export materials time= 0.075 ms
Collect objects time= 0.045 ms
Mesh creation time = 3.971 ms.
Loaded Octane DLL:Octane X Prime 2022.1 XB 3 version:12000004 SDK:2022.1 XB 3
Octane X for Cinema 4D 2022.1-XB3-(R3) built for:250 C4D vers:25120
C4D:25120 comp:[Howard’s MacBook Pro] OS:[OS X 64 BIT] macOS: Version 12.5 (Build 21G72) versType:10
CPU:[GenuineIntel, stepping 0, model 12, instruction family 6] speed:2.4 GHz numOfCpu:10
Plugins:[addons advanced_render alembic archigrass assetbrowser bitmapfilter bpexchange browser bugslife_client c4d_emulation c4d_viewport_render c4doctane-R25 ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing deltamush deployment dwg dwgobjects dynamics exchanges expressiontag fbx gltf goz hair i_skp interop interop_forger io_forger io_obj metrics mkmodeler mocca model mograph motioncam motiontracker nbo nbp newman nodeeditor objects onlineupdater physx_hybrid projectassetinspector python redshift redshift4c4d relaxuv scenemanager2 sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender thinking_particles tool_system_hybrid tpoperators usd uvviewport volumes xpressocore xtensions ]
Loaded 175 osl scripts from dir:/Users/howardphillips/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/plugins/c4dOctane/res/osl_scripts
convert mat:[OctDiffuse1] tip:1029501
<<< Render failure detected!!! >>>
Please check render statistics to solve the problem.
OCT: MB:0/0 ST/MOV:0/2 Nodes:18 Tris:1k DispTris:0 Hairs:0 Meshes:3
OCT: Textures Grey8/16:0/0 Rgb32/64:0/2
File not found:/Users/howardphillips/Library/Preferences/Maxon/Maxon Cinema 4D R25_EBA43BEE/updates2020.txt
>> ProcessUpdate(flags=CM cAsyn=0 dDelay=1
>> ProcessUpdate end res:0 tm:0.004ms.
OCT:--------------------------- EXPORT LOG ---------------------------
ResetAndInit 1
ResetAndInit [OK]
>> ProcessUpdate end res:0 tm:0.005ms.
OCT: MB:0/0 ST/MOV:0/2 Nodes:17 Tris:1k DispTris:0 Hairs:0 Meshes:3
convert mat:[OctUniversal1] tip:1029501
ResetAndInit 1
ResetAndInit [OK]
OCT: MB:0/0 ST/MOV:0/2 Nodes:15 Tris:1k DispTris:0 Hairs:0 Meshes:3
>> ProcessUpdate(flags=CMOG cAsyn=1 dDelay=1
>> ProcessUpdate end res:0 tm:0.003ms.
ResetAndInit 1
ResetAndInit [OK]
OCT: MB:0/0 ST/MOV:0/0 Nodes:11 Tris:2 DispTris:0 Hairs:0 Meshes:1
altestudio
ok I just updated to r26 and it seems to be working now
Ron
aoktar wrote: It requires min 26.107 and OSX 12.3. And M1 system. Disable rosetta for Cinema4D
I am using R26.107, IOS 12.5.1 on Macbook Pro M1.
The plugin will not show up under Extensions.
I tested all versions of plugin in plugins folder under preferences and apps/cinema4D
Regards - Ron
Delete unused *.xdl64 files
