Version 3.06.2 - obsolete stable
petesand
Netrendering doesn't work due to the fact that the version numbers are different.
I tried the newest C4D Plugin and the version number is 3060003 but i need
3060005 which is the corresponding "Octane Render number".
Where can i find the right C4D plugin?
Cheers
pete
petesand wrote:Hi,
Cheers
pete
It's different because you're using test4 version of standalone. Update your standalone not C4D plugin.
Studio21
Hey ahmet,
is the triplannar projection feature in the next release? its currently missing from the plugin.
Thx,
Guy
valters
Hi, I'm very sorry that i'm putting this not in general forum part but please can somebody tell is that is possible to freeze frame from VDB? I need to stop playback of VDB on specific frame for some time and then continue to play sequence.
If there is no such a option can you add the control of playback ... even with offset? As example adding checkbox "AutoPlay" and if its off then we can control playback using offset! :D
Studio21 wrote:Hey ahmet,
Thx,
Guy
I've added it. I can give a private copy for testing. Please send me a PM with version+OSX you need.
Terryvfx
Hello there! I found out that the tri-planar solution in Octane came in two flavors one is the tri-planar mapping node (which we have in the plug-in) but I found out we also have a blend-box cube transform node that is much more useful for general use and we don't have this one in the plugin, are you planning to add this one in the future?
BTW: I've been using the Ref Shader node and I love it! great job!
Terryvfx wrote:Hello there! I found out that the tri-planar solution in Octane came in two flavors one is the tri-planar mapping node (which we have in the plug-in) but I found out we also have a blend-box cube transform node that is much more useful for general use and we don't have this one in the plugin, are you planning to add this one in the future?
same question one post above i think: viewtopic.php?f=85&t=60816&start=90#p312678
Terryvfx
You are right! LOL I even search the thread for the term to see if someone said something then found nothing and straight up posted the question guess I should read the whole thing next time haha BTW I would glady test that one out :D
Studio21
Sorry for my ignorance but what do u use the ref shader for? i didnt see any documentation on this
Best
Guy
underworldtr
valters wrote:Hi, I'm very sorry that i'm putting this not in general forum part but please can somebody tell is that is possible to freeze frame from VDB? I need to stop playback of VDB on specific frame for some time and then continue to play sequence.
1- Create 3 separate vdb volume on same coordinates&specs. One for image sequence / one for static image (time freeze effect) / one for final animation
3- Turn on "static image" visibility when the "image sequence" is done for you / Turn off image sequence visibility on same time.
4- Complete time freeze animation to reach one specific frame we need back to normal time flow. (Camera movement etc.)
5- Offset 3rd vdb volume's image sequence to complete the rest of the animation. Turn off "static image" visibility off.
I didn't try but I think it will work. Sorry for my English.
C4D r18.048 / Octane Render Plug-in 3.06 / Turbulence FD (Build 1425) / X Particles 3.5
Titan X & GTX 1080
Win 7 Ultimate
