Version 2.21.1
martinzip wrote:Hello
is the 2.21.1 stable for a production??
kind regards
martin
it's not yet perfect. It's near to ok for me but can't guarantee it very solid. Still having some problems, 2.22 will be better
NikkyyHD
I have researched everywhere, spent hours trying to troubleshoot this, saw several posts about it but no answer - please help - Motion blur renders with beauty passes just fine, BUT AO pass will NOT render with motion blur, what am I missing? I feel like I have tried everything. Help would be much appreciated.
i7 6950x | 7 x Titan XP 3 x GTX980 | 128GB RAM youtube.com/nikkyyhd
NikkyyHD wrote:I have researched everywhere, spent hours trying to troubleshoot this, saw several posts about it but no answer - please help - Motion blur renders with beauty passes just fine, BUT AO pass will NOT render with motion blur, what am I missing? I feel like I have tried everything. Help would be much appreciated.
Hi there,
Implementation is very new. It's not a part of beauty passes, on info passes. It may not support this, i'll check it.
NikkyyHD
Thanks for the fast reply! If it helps - running Cinema 4D R13 and everything works excellent with the plugin - Depth of Field DOES work in info passes, but motion blur does not (for me, at least.) Thanks very much for your time:)
NikkyyHD wrote:Thanks for the fast reply! If it helps - running Cinema 4D R13 and everything works excellent with the plugin - Depth of Field DOES work in info passes, but motion blur does not (for me, at least.) Thanks very much for your time:)
i see same here. I'll ask to Strafied for this.
stratified
Hi guys,
This is a bug in the current release. Will be fixed in the next release.
cheers,
Thomas
garytyler
I decided to try an animation .orbx export and my system freezes on it. I can do single frame .orbx scenes like normal. I tried cutting the scene to only a few frames but it still freezes.
Win 8.1 / C4D R16 / Maya '16 / 5x GTX 980 Ti
garytyler wrote:I decided to try an animation .orbx export and my system freezes on it. I can do single frame .orbx scenes like normal. I tried cutting the scene to only a few frames but it still freezes.
will take much longer than single. probably it's processing in background until last frame. I'll put a better progress counter or window.
garytyler
Makes sense! Thanks aoktar.
grain
Are the new stereoscopic pano camera modes from the standalone version accessible through the Cinema plugin? I can't see them there, just the normal mono panorama modes.
