Cinema4D version 2021.1.7 (Old stable) 16.12.2022
Octane custom color sliders are great because they doesn't block render engine from continous rendering. All other C4D sliders and gradients cause that Octane stop rendering until mouse button is released.
yes It's why I created it.SSmolak wrote:Octane custom color sliders are great because they doesn't block render engine from continous rendering. All other C4D sliders and gradients cause that Octane stop rendering until mouse button is released.
Are they in 2022 too ? I didn't notice differencies ? I mean "other" sliders and gradients ? Is there something new in this 2021 build ? I'm using 2022 at the moment.aoktar wrote: yes It's why I created it.
- turtles123
The octane light tag bug its fixed for me, thanks a lot.
Hi there! using the latest stable I'm having this weird issue where octane and c4d both crash when double-clicking a knot in the octane gradient node. It seems to work fine if I change the color without double clicking (using the menu below the knot) but the double-clicking is so ingrained in my muscle memory that it is a bit of a problem.
Hi,DiegoCP wrote:Hi there! using the latest stable I'm having this weird issue where octane and c4d both crash when double-clicking a knot in the octane gradient node. It seems to work fine if I change the color without double clicking (using the menu below the knot) but the double-clicking is so ingrained in my muscle memory that it is a bit of a problem.
we cannot reproduce this issue here, maybe plugin is not installed correctly
Please write to help at otoy dot com so we can investigate more deeply.
ciao,
Beppe
- stefano-dear
I too have many crash problems with this version.
With Cinema 4D 2023 the situation is even worse!
Win 10 + RTX 3090 - Bug report attached
- Attachments
- bugreport_20220927_181755.zip
- (14.85 KiB) Downloaded 158 times
do you have a more stable one for you? It looks like you're sending a report from 2021.1.5. Also there's a compilation error from geometry accelerator. Do you have vertex displacements?stefano-dear wrote:I too have many crash problems with this version.
With Cinema 4D 2023 the situation is even worse!![]()
- stefano-dear
I also tried version 2021.1.6 but it still crashes. I only have one texture displacementaoktar wrote:do you have a more stable one for you? It looks like you're sending a report from 2021.1.5. Also there's a compilation error from geometry accelerator. Do you have vertex displacements?stefano-dear wrote:I too have many crash problems with this version.
It's looks like your geometries or vertex displacement. Having one displacement doesn't mean that will not crash. It's possible if you go high on tessellation.stefano-dear wrote: I also tried version 2021.1.6 but it still crashes. I only have one texture displacement
