Cinema4D version 2021.1.5-(R4) (Stable 2021) 28.06.2022
SSmolak
Animal006 wrote:Hi
I also get a black live viewer image when I enable 'store render buffer'.
Running C4D R26.015 with latest Nvidia driver 512.96.
Any idea what can cause this?
Thanks!
I had the same. To resolve it there is need to remove previous stored image.
Also it generate black screen while using AI Upsampler
Animal006 wrote:Hi
Thanks!
Every case or specific one?
Animal006
aoktar wrote:
Animal006 wrote:Hi
Thanks!
Hi aoktar,
Thanks for the reply!
It's in every case. Whether I start a new project or open a previous one.
Animal006
SSmolak wrote:
Animal006 wrote:Hi
Thanks!
Thanks for the suggestion!
AI Upsampler is turned off. I once managed to resolve it by removing the previous stored image as you suggested. But it seems it doesn't always work.
Animal006 wrote:Hi,
It doesn't occurs on me. You should give the more solid info to get help.
Animal006
Ok, then the problem lies at my side!
I'll try a clean install of the Nvidia driver, before I waste your time.
SSmolak
Animal006 wrote:Ok, then the problem lies at my side!
No this is no problem on your side :
LV_storeimage.zip
(688.87 KiB) Downloaded 160 times
It probably is caused after changing some OSL nodes in material.
rrbarb
I am seeing this Store Render Buffer issue across multiple machines. And multiple "recent" versions of c4d-octane-nvidia - real mystery at this point- but it is happening here. Still digging on it.
./rrb
SSmolak
I noticed that there is need to manually change stored image to previous one and after at again to the last one or sometimes remove image and it will works fine. Somewhat like stuck image issue.
rrbarb
rrbarb wrote:I am seeing this Store Render Buffer issue across multiple machines. And multiple "recent" versions of c4d-octane-nvidia - real mystery at this point- but it is happening here. Still digging on it.
./rrb
No OSL - Nor AI Up sample in jobs.
./rrb
