Cinema 4D version 4.05-R7 (V4 stable) 25.10.2019
marshalartist
Hi Aoktar, it was the C4D texture manager causing the problem the Octane version is fine. I think I got a bit carried away with the layout.
marshalartist wrote:Hi Aoktar, it was the C4D texture manager causing the problem the Octane version is fine. I think I got a bit carried away with the layout.
Hmm, so there may not be much things to fix it. I'll try to reproduce the issue. Thanks!
marshalartist
Spoke to soon, it is the same problem with the Octane texture manager as well
marshalartist wrote:Spoke to soon, it is the same problem with the Octane texture manager as well
Is it happening on a specific scene?
marshalartist
it happens with any of our room set scenes
marshalartist
the scenes load instantly without the texture managers but fail to load with them docked in the layout
marshalartist wrote:the scenes load instantly without the texture managers but fail to load with them docked in the layout
C4D version? It doesn't crash on me with R19
marshalartist
R20 - does not always crash but it is unresponsive for a very long time
marshalartist wrote:R20 - does not always crash but it is unresponsive for a very long time
Are you forcing it to crash without waiting the completion of update process? If you do, it will crash. Are you sure it's specific to octane scenes? Did you check with c4d scenes with a lot of textures?
It may take much time if you have lot of texture search paths in preferences. Even if paths are on network or external devices
marshalartist
I did explain that without the texture managers that the scenes open instantly, but with the managers docked they take forever or crash. We only have C4D octane scenes not standard C4D scenes, I don't see how this is relevant though, it all worked fine in R4.01. Thank you for looking into this though, it is not much of a hindrance now we know what it is.
