OctaneRender 4 for DAZ Studio [TEST and STABLE] [OBSOLETE]
Moderator: BK
19:41:01.462: ORC user subscription status could not be retrieved: The server returned a client-side error with HTTP code: 401
I believe that this error was due to a problem on the OTOY servers, and has been resolved now. If you continue to get that error, please report it here and I will investigate further.
rajib
I am posting a link of a bug I found. I have described the issue in this post under V2018.1 viewtopic.php?f=44&t=71080&p=361687#p361687. It effects V4 too.
Windows 10 Pro i9-9980XE 128GB RAM|4 x Titan RTX
Houdini 18.5(2020.2.1.2)|Cinema C4D R26|Daz Studio Pro 4.21.0.5(Octane 2021.1.6.83)
NVIDIA 460.89 Studio Standard
RGUS
How to change all materials of clothing particularly to diffused material?
I've had a search for an answer or solution, but couldn't find anything.
It happens with most materials from merchants loaded into DAZ Studio and then rendered in Octane, the material all come out glossy.
Is there a variable or setting that loads material with diffused material automatically?
WEB: http://rgus.deviantart.com/
GPU: NVIDIA GeForce RTX 3090 Ti
RAM: 64GB
CPU: 12th Gen Intel(R) Core(TM) i9-12900K 3.20 GHz
OPERATING SYSTEM: Windows 11 Pro
OCTANE PLUGIN VERSION: 2022.1..1.302 Prime
DAZ STUDIO VERSION: 4.21.0.5 Pro Edition (64 bit)
wader
RGUS wrote:How to change all materials of clothing particularly to diffused material?
I have not found a way to augment or override existing Daz material -> Octane material mappings which occur from automatic material conversions. Usually I need to tweak a number of automatic conversions, some more than others depending upon how the scene was setup by the content author.
Over time, I have been saving my changes which need to be made frequently into My Presets in the Octane plug-in and have also been building favorite Octane-based materials for common needs (e.g., glass, water, cloths, leathers, rugs, etc.) in a local folder/database that can be used with the System tab -> OctaneRender import -> Materials function.
If you are looking to change a number of surfaces to the same basic material, I have found that drag/drop from the left side of the Octane plugin's Materials tab to the surfaces is reasonably quick - then, tweak each one from there. That's why I keep a number of favorite starting point materials in the My Presets section.
Windows 10 Pro 64-bit | Ryzen 9 5950X | ASUS Pro WS X570-ACE | 64GB |{ASUS ROG Strix GTX 3090 24GB + (2x) Titan X Pascal 12GB}
I have updated the installers at the top of this thread with:
4.04.0.44
- Compiled with Octane 4.04
SimonJM
Out of curiosity, now updates for Octane 4 have, effectively, ceased, what happens when Daz release an updated Daz Studio with a revised SDK and plug-ins cease to work (unless/until re-compiled and/or any work required to conform to anything new)?
itou31
I think that we will stuck with the lastest version that works. Else, I think that we will go through Iray for the next Daz Studio 5. :roll:
I7-3930K 64Go RAM Win8.1pro , main 3 titans + 780Ti
Xeon 2696V3 64Go RAM Win8.1/win10/win7, 2x 1080Ti + 3x 980Ti + 2x Titan Black
SimonJM
itou31 wrote:I think that we will stuck with the lastest version that works. Else, I think that we will go through Iray for the next Daz Studio 5. :roll:
That suggests keeping, if at all possible, a 'down-level' version of Daz Studio.
In this case I would probably release an Octane 4 version of the plugin.
SimonJM
That is good news, thank you.
Return to “DAZ Studio”
