OctaneRender™ 4.0 for LightWave™ - Beta build 4.00.0.8 XB3
juanjgon
pixym wrote:I have an odd issue, Instances does not render ;-(
Has somebody noticed that ?
Please, check if you have the master objects enabled in the scene editor.
pixym
Hello Juanjo,
Yes they are checked…
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10 64
NET RENDER : MB ASUS P9X79 - Intel i7 - Ram 16GB - Two RTX 3080 TI - Win 10 64
pixym
It seems to be okay right now. I had to Redraw…
Shame on me :o
AndyM1969
XB4 coming soon?
promity
Somebody faced with the fact that it is impossible to deactivate different video cards - the renderer always goes to all available GPUs in Octane 4 XB3?
At first I thought that the render only goes on one video card. But when I looked at the graphic of load of video cards - I saw that all GPUs participate in the render irrespective of which of them are activated in the plug-in settings.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
juanjgon
promity wrote:Somebody faced with the fact that it is impossible to deactivate different video cards - the renderer always goes to all available GPUs in Octane 4 XB3?
Yes, this is bug on the plugin side. It will be fixed in the upcoming new plugin build with the Octane XB4 core.
BorisGoreta
Is that the reason I couldn't play Battlefield 1 properly while it was renderning ?
EDIT: no, GPU selection is working fine here.
juanjgon
BorisGoreta wrote:Is that the reason I couldn't play Battlefield 1 properly while it was renderning ?
The GPUs selection works fine in the IPR, or if you switch the GPUs using the IPR or the preview window, but when you press F9/F10 usually all the GPUs are selected for rendering due to a bug that has been already fixed for the next build.
royk
some texture maps can't come out
BorisGoreta
I had the same issue with axyz models, try putting the textures in another folder like desktop or converting them to jpg.
Return to “Lightwave 3D”
