OctaneRender 3 for DAZ Studio [TEST and STABLE] [OBSOLETE]
Moderator: BK
if displacement maps are to be used, should the normal and bump maps still be removed ?
I'm not absolutely sure on this. You will need to check with OTOY.
I have updated the installer at the top of this thread with:
3.4.2.27
- Compiled with Octane 3.04.2
- [UNTESTED] The "Replace All Active Maps" function now replaces Normal maps in addition to the other maps. Displacement maps are still not replaced
- The material conversion process will now allow both bump and normal maps to be used (whereas in the past if there was a normal map, the bump map would be ignored)
- Fixed issue where the standard SSS skin shader was not using the normal and bump maps in both materials in the material mix
wlebrun
Happy Halloween!
Wanted to check in and see if it is a good time to ask if HDR Lightmap integration with Daz Studio can yet be put on the map again.
Cheers
Version 3 of Poser 3.3.4.77/ Daz 3.3.4.25/ 3DS Max 3.03.4 - 4.20 octane plugins
X79 Sabertooth - i7-3930K 48GB RAM
MSI 1070 8GB Liquid Cooled
Windows 10 Pro x64 (ver. 1607)
Sorel
I'm so happy to be able to use normal and bumps on the same material, no more having to find other ways to make them work together.
DrHemulen
Yes, this is a very hefty upgrade :)
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
3.4.3.27
- Compiled with Octane 3.04.3
rajib
face_off wrote:I have updated the installer at the top of this thread with:
3.4.3.27
Thanks Paul :) .
Windows 10 Pro i9-9980XE 128GB RAM|4 x Titan RTX
Houdini 18.5(2020.2.1.2)|Cinema C4D R26|Daz Studio Pro 4.21.0.5(Octane 2021.1.6.83)
NVIDIA 460.89 Studio Standard
panergaard
A slightly annoying bug:
DAZ Studio crashes when marking more than one material and "Copy as new materials".
Reproduction steps:
1 Open DAZ Studio with empty scene
2 In material tabs, select a material from Live DB and rightclick selecting Copy as new material
3 Selecting the copied material, short, and rightclick selecting Copy as new material
4 Selecting BOTH copied materials, short, and rightclick selecting Copy as new materials
5 DAZ Studio dies with exception reason:
"DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\plugins\OctaneRender\plordazs.dll" at 0033:000000001633FCFA, DzMatrix4::`default constructor closure'()+1157722 byte(s)"
DAZ Studio 4.9.2.70
OcDS 3.4.3.27
Win7, 64 GB RAM
Titan Black + Titan X + Titan Z
I can reproduce this error, and will try to put a fix in the next release.
AlfaseeD
Hello Paul
do you have any idea what this line means ?
DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Windows\system32\nvcuda.dll" at 0033:00000000E1D5682A, cuD3D10GetDevices()+2879244 byte(s)
Thanks !
Return to “DAZ Studio”
