Version 2.12.2 - final (updated on 18.11.14)
eyeonestudio
In LV
Start LV with empty scene
Triangle info error....
NVN wrote:hi aoktar.
i cant use Displacement.
It is normal?
Tested in r14 and 15.
also if i have Only Octane as plugin in the plugin folder...
please refer displacement part on manual. I think that would be explained well
eyeonestudio wrote:In LV
yes i see, thanks
mossberg385t
I believe there is a vram leak with RC2. The longer I work more vram becomes unavailable despite my scene only being 27mb per the octane stats. I noticed this when it said my titan only had 1.6gb available, I closed Cinema 4D and immediately all vram became available.
I will test this more later this evening but it seems as though it is not flushing the scene data for each frame of animation as I scrub through the timeline.
4930k @ 4.4ghz | 2x EVGA 980 Ti Classified @ 1490mhz | EVGA 1300G2 | Gigabyte x79-UP4 | 250gb 840 EVO boot | 128gb 840 Pro cache| ATTO R680 | G Speed eS Pro 8tb
Cooling: 2x EK FC780-Classy GPU Block | 2x XSPC AX360 | XSPC Photon D5 170 | XSPC Raystorm
mossberg385t wrote:I believe there is a vram leak with RC2. The longer I work more vram becomes unavailable despite my scene only being 27mb per the octane stats. I noticed this when it said my titan only had 1.6gb available, I closed Cinema 4D and immediately all vram became available.
Please post a test scene if it's reproductable. I can't say anythings without see that. Thanks
volkmar
hi
i have an issue with the new version. i get occasional complete crashes on my macpro. it never happens during rendering. later when i switch to a different job, suddenly i get a black screen and the mac starts rebooting. i think its clearly related to working with octane.
the other thing is still the vram usage. although i found the workaround with the tiled camera i am still puzzled by the fact that i cant even render a cube in high resolution (>4500 pixel) with 1.2 gb vram.
cheers
volkmar
sadece
LV restarts the rendering when i move the mouse on Viewport of C4d. A bug or usual behavior for new versions?
http://www.sadece.com.tr
i7 990x // 12GB Ram // 2x Titan X + Titan + 780 // Octane for C4D // Win7 x64
volkmar wrote:hi
cheers
volkmar
1.2gb vram? Is it free or total? what do you see on LV while working?
sadece wrote:LV restarts the rendering when i move the mouse on Viewport of C4d. A bug or usual behavior for new versions?
Honestly, restarting can occurs due c4d's messaging system and plugin controls. I have notified RC2 was compiled with a parameter which is disabled mistakely. So RC1 is still better on updating. I'll fix it.
volkmar
its free vram. in liveviewer no problems. its only they superhigh resolutions.
