Yep scratch that would be the correct work around for now.
Filed another fogbugz about vertex normals in Layout... Hope NT can fix it
Any news about an update for the exporter ?..
GTX260 Seven 64bit
I'm Superfrog
I'm Superfrog
Going through modeler is a temporary solution.
GTX260 Seven 64bit
I'm Superfrog
I'm Superfrog
Any news about an update of the lw exporter?
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
Hi Holocube,
Look at this post. !!!
http://forums.newtek.com/showthread.php ... ex+normals
Maybe Sensei can help fix the obj exporter?
"Export is buggy - there is written just one normal vector per vertex.
(But there is needed one normal vector per vertex per polygon)
So after importing there is everything smoothed- you like see in your cube.
I will have to write mine own OBJ exporter (1h of work or so) and put to TrueArt's Modeling Pack http://modelingpack.trueart.eu
because I am often using OBJ export and see and suffer because of this issue."
Win7 Sp2____2xGTX1060 [email protected]____Su17.2.2555 and Su18.0.16975____SketchUp Plugin 4.00.0.17____4.00.RC7 Standalone
Looks like if only the exporter triangulate the smooth surfaces everything would be OK(but what do I know, I'm not a programmer)!
(And now, triangulate everything in LW is not a solution
-Juanjo, after the release of the fully integrated plugin?
Pleeesss
Pleeesss
guy rabiller | radfac founder | ceo
