Cinema4D version 2020.1.5-R4 (Obsolete stable) 17.10.2020
Seun116_1
I'm running into issues with "Pick Focus" while "Lock Resolution" is enabled on this build
Seun116_1 wrote:I'm running into issues with "Pick Focus" while "Lock Resolution" is enabled on this build
Which build and C4D? What's resolution and desktop scaling ratio?
Seun116_1
202.1.5-R2 on C4D R21.207. I'm currently using 1920x1080 and I've tried various scaling ratio with the same problem. When I disable "Lock Resolution" it works perfectly.
mtb_mike
mtb_mike wrote:Getting some strange artifacting in the LV with this release. Viewport rendering works ok. Forgot to try an actual render. Downgraded to 2020.1.4 and back to normal. Mac High Serria, S22, 1080ti, akitio node.
So far so good with R2. Thanks
iMac 4.2 GHz 40GB RAM | OS 10.13.6 C4D r20 Octane 4.02.1-R3 | Akitio Node with GTX 1080 Ti | Nvidia driver 387.10.10.10.40.122 | Cuda 410.130
Windows 10 Network Render System with Four GTX 970s, Same Octane Version
thodosplay998
Hi Aoktar!
Any approximated ETA for Scene nodes to show in Octane?
thodosplay998 wrote:Hi Aoktar!
I haven't tested or worked on these. So can't give any timing, sorry!
Try R3 build.
Seun116_1
Yep! Pick Focus works with Lock Resolution enabled now. Thanks! I am wondering what the difference is between the two scaling options is.
Seun116_1 wrote:Yep! Pick Focus works with Lock Resolution enabled now. Thanks! I am wondering what the difference is between the two scaling options is.
First is for resolution scaling, second is zoom factor for canvas
maged99
works fine so far on R23, thank you
Win 10 lastest
Rayzn 1700x, 32gb of ram
Rtx 2070, vendor: msi
Octane for C4D
With latest Nvidida Studio Drivers always
