Cinema4D version 2020.1.5-R4 (Obsolete stable) 17.10.2020
Which build and C4D? What's resolution and desktop scaling ratio?Seun116_1 wrote:I'm running into issues with "Pick Focus" while "Lock Resolution" is enabled on this build
202.1.5-R2 on C4D R21.207. I'm currently using 1920x1080 and I've tried various scaling ratio with the same problem. When I disable "Lock Resolution" it works perfectly.aoktar wrote:Which build and C4D? What's resolution and desktop scaling ratio?Seun116_1 wrote:I'm running into issues with "Pick Focus" while "Lock Resolution" is enabled on this build
So far so good with R2. Thanksmtb_mike wrote:Getting some strange artifacting in the LV with this release. Viewport rendering works ok. Forgot to try an actual render. Downgraded to 2020.1.4 and back to normal. Mac High Serria, S22, 1080ti, akitio node.
iMac 4.2 GHz 40GB RAM | OS 10.13.6  C4D r20  Octane 4.02.1-R3 | Akitio Node with GTX 1080 Ti | Nvidia driver 387.10.10.10.40.122 | Cuda 410.130
Windows 10 Network Render System with Four GTX 970s, Same Octane Version
- thodosplay998
 - Contact:
Hi Aoktar!
Any approximated ETA for Scene nodes to show in Octane?
Win 10, RTX 2070 S
Https://cataclysm-vfx.com/
Https://instagram.com/thodos998
Octane SMC Plugin: https://gum.co/octmat
I haven't tested or worked on these. So can't give any timing, sorry!thodosplay998 wrote:Hi Aoktar!
Try R3 build.Seun116_1 wrote:202.1.5-R2 on C4D R21.207. I'm currently using 1920x1080 and I've tried various scaling ratio with the same problem. When I disable "Lock Resolution" it works perfectly.aoktar wrote:Which build and C4D? What's resolution and desktop scaling ratio?Seun116_1 wrote:I'm running into issues with "Pick Focus" while "Lock Resolution" is enabled on this build
First is for resolution scaling, second is zoom factor for canvasSeun116_1 wrote:Yep! Pick Focus works with Lock Resolution enabled now. Thanks! I am wondering what the difference is between the two scaling options is.
