Cinema 4D version 2018.1-R3(obsoletestable) - 29.03.2019
ryjohnson-loaded wrote:With this version I seem to be unable to render with all four of my GPUs, I'm only able to render with two of them - I have the subscription.
When checking the boxes in the settings on my third and fourth GPU, nothing seems to happen, and when re-opening the settings dialogue again, they remain unchecked.
Currently running NVIDIA "Creator Ready Driver" 419.67
4x NVIDIA GeForce RTX 2080 Ti
Windows 10 Pro 10.0.17763
Cinema 4D R20.059 Studio
Intel Xeon W-2125 @4.00GHz
128 GB RAM
from 2018, Studio versions are limited to 2x GPUs, withot Network Rendering feature.
You need to go back to v4 for 4x GPUs, or switch your Studio license into an Enterprise AA license.
ciao Beppe
alperenozgur
this version makes c4d 20.059 ( latest update ) freeze at splash screen for me. and stays like that until i kill it from task manager. anyone else?
alperenozgur wrote:this version makes c4d 20.059 ( latest update ) freeze at splash screen for me. and stays like that until i kill it from task manager. anyone else?
What's your driver version Alperen?
alperenozgur
hi, creator ready 419.67. i have rtx 2070.
Kalua
This Custom LUT combobox is great!!
Thanks, Aoktar!
One question: why did the region render behavior change since v4 or so? It used to add render samples to the main render but now it restarts at every new region set. Stand alone has never changed this behavior.
Cheers!
C4D 2025.3.3 Octane v1.9.4 // Octane SA 2026.4, Windows 11 Pro, X399, AMD TR 2950X, <<2 X 3090 + NVlink>>, 128 GB RAM, Corsair 1500i - NVIDIA SD 610.62
Octane User since V1 Beta
Kalua wrote:This Custom LUT combobox is great!!
Thanks, Aoktar!
Cheers!
I need to check. Plugins can be different due different environment and workflow of host software.
alperenozgur
R3, same issue.
Have you correctly installed it?
Find "c4doctanelog.txt" and post here
alperenozgur
[2019-03-30 00:59:36][1] RegisterOctaneLive()
[2019-03-30 00:59:36][0] Loaded Octane DLL:OctaneRender Studio 2018.1 version:5000010 SDK:2018.1
[2019-03-30 00:59:36][0] Octane Render VR for Cinema 4D 2018.1-R3 built for:200 C4D vers:20059
[2019-03-30 00:59:36][0] C4D:20059 comp:[DESKTOP] OS:[WINDOWS 64 BIT] Windows 10, 64 Bit, Professional Edition (build 17763) opengl:460 sysInfo:32 versType:2
[2019-03-30 00:59:36][0] CPU:[GenuineIntel, stepping 2, model 15, instruction family 6] speed:3.3 GHz numOfCpu:12Ht
[2019-03-30 00:59:36][0] Plugins:[houdiniconfig addons advanced render alembic archigrass bitmapfilter bpexchange browser c4dOctane-R20 c4dtoa ca ca2 cadexchange clothilde collada14 collada15 colorchoosergui compositing dwg dwgobjects dynamics exchanges expressiontag fbx gpurenderer hair i_skp iges io_obj licenseserver metrics mkmodeler mocca model mograph motioncam motiontracker nbp newman nodeeditor objects onlinehelp onlineupdater python relaxuv sculpt sculptbrushes shader sketch sky sla spacemouse substance teamrender texturemanager thinking particles tpoperators volumes walkthrough xpressocore xtensions ]
[2019-03-30 00:59:37][1] LoadOslScripts()
[2019-03-30 00:59:37][1] LoadCustomLuts()
stops there
SRCOBB
I'm still having no luck with 2018. V4 works fine. 2018 freezes up regularly. I can work maybe ten minutes on the simplest thing and I will get a spinning beachball when Octane tries to update materials or it will often say "Octane: checking others time: xx.xx..."
As was said before, it seems I always have problems.
I wonder if it's because I have an older mac using Nvidia cards with CUDA drivers?
Here's my setup:
Mac Pro 2010
OSX 10.13.6
36 GB RAM
2x Nvidia Geforce Titan X 2mb
CUDA driver version 410.130 (GPU driver version 387.10.10.10.40.113)
C4D R20
Any thoughts?
