Hi coilbook,
checking "receving shadow" and/or "shadow cast" in object proprierties, apply and rebuild scene.
Regards
Paride
OctaneRender® for 3ds max® v4.00-XB3 - 6.01 [TEST][OBSOLETE]
- paride4331
I'm getting this - see the eatean up balls, like a square selection is not rendered.. I disabled and enabled everything I could think off - sort of worked better just rendering on a single 980ti.. 1080ti as primary - but also that's not constant.. any ideas?
this is how it has to come out - balls with numbers
3dmax, zbrush, UE
//Behance profile //BOONAR
- paride4331
Hi acc24ex,
could you confirm all works ok using 3.08?
Setting all "movable proxy" is your issue fixed?
If not, could you kindly share your file, in pm, please?
regards
Paride
regards
Paride
- senorpablo
I'm getting similar clipping issues on animated parts.
HI Paride,
do you know by any chance how to create laser similar to this video. We need it to scan the cave same way https://youtu.be/3jeUTcNucYY?t=9s
is it even possible with octane?
Thank you
Thank you
- paride4331
Hi coilbook,coilbook wrote:HI Paride,
Thank you
maybe something like that, adjusting as you need.
Regards
Paride
- Attachments
- 01.zip
- (148.4 KiB) Downloaded 280 times
Thank you looks greatparide4331 wrote:Hi coilbook,coilbook wrote:HI Paride,
Thank you
Regards
Paride
