OctaneRender® for 3ds max® v4.00-XB3 - 6.01 [TEST][OBSOLETE]
paride4331
Hi coilbook,
checking "receving shadow" and/or "shadow cast" in object proprierties, apply and rebuild scene.
acc24ex
I'm getting this - see the eatean up balls, like a square selection is not rendered.. I disabled and enabled everything I could think off - sort of worked better just rendering on a single 980ti.. 1080ti as primary - but also that's not constant.. any ideas?
this is how it has to come out - balls with numbers
paride4331
Hi acc24ex,
could you confirm all works ok using 3.08?
Setting all "movable proxy" is your issue fixed?
If not, could you kindly share your file, in pm, please?
regards
senorpablo
I'm getting similar clipping issues on animated parts.
coilbook
HI Paride,
do you know by any chance how to create laser similar to this video. We need it to scan the cave same way https://youtu.be/3jeUTcNucYY?t=9s
is it even possible with octane?
Thank you
paride4331
coilbook wrote:HI Paride,
Thank you
Hi coilbook,
maybe something like that, adjusting as you need.
01.zip
(148.4 KiB) Downloaded 237 times
coilbook
Thank you
Hi coilbook,
Thank you looks great
Return to “Releases”
