I mean exactly that, check out this video for max 2014. It doent do it every time, but a lot of the times.paride4331 wrote:Hi darkline,darkline wrote:Hi
In this new version, if I have an alpha channel and choose to use a backplate (use viewport background), it displays fine when I first open the octane viewport; however if I lock the camera and change viewports then the background dissapears and only displays the checkered alpha. I have to close the octane viewport and re-open to get my background image back again.
Max 2014 here.
I do not think 4.40 has background problems in 3dsmax 2014, or I did not understand the issue.
Attached to a video clip. Is this correct?
Regards
Paride
OctaneRender® for 3ds max® v3.06.4 - 4.40 [OBSOLETE]
- Attachments
- background image.mp4
- (43.34 MiB) Downloaded 2879 times
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
- paride4331
HI darkline,darkline wrote:I mean exactly that, check out this video for max 2014. It doent do it every time, but a lot of the times.paride4331 wrote:Hi darkline,darkline wrote:Hi
Max 2014 here.
Regards
Paride
I'm testing 4.41, i tested it on 3dsMax2014 i did not find issue you report,
attached a scene for you, have you issue using 4.40 with that?
Regards
Paride
Hi paride4331, something has cleared up on my problem? In new 3.06.4 - 4.41 version same, does not work.paride4331 wrote:@mikinik
Hi miknik,
thanks I'm testing your issue; I'll let you know as soon as possible.
Regards
Paride
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
- paride4331
Hi miknik,
I did the tests again, I create a new .abc, personally I think there is something wrong around the .abc you made;
maybe some issues about normals or exporting you made.
Attached a test created with phoenix, it works fine.
Regards
Paride
Regards
Paride
- Attachments
- test.zip
- (7.81 MiB) Downloaded 277 times
Hi Paride,
might aswell test the new version and I'll report back next week.
another thing ive noticed is the render re-starts when switching from the beauty pass to noise pass in the octane viewer. Very annoying when you're trying to flick between the two to assess acceptable noise levels.
- paride4331
Hi darkline,
testing 4.41 in 3ds Max 2014-2018 I did not find any issues about this.
the samples do not resumes witching from beauty to noise and vice versa.
Let me hear from you.
Regards
Paride
Regards
Paride
