Version 2.20.0 RC2 - Release candicate 2
cbmotion wrote:Hi Ahmet -
again - thank you for your excellent work!!!!! i love octane
But your rendermask-sample1 build only one mask at my render. ist this a mac problem/bug?
i didnt change anything in the settings
cheers
carsten
To use objects with objecttags for movement, opacity, layer/object id, etc... You should select render method2: "resend only updated objects". This method is default anymore to be away this kind of user feedbacks. Thanks
garytyler
I've only had this open for 5 minutes but so far the sliders seem to be updating perfectly!!! Also, the new overlay and rendering bar looks great. Thank you Ahmed!!!
Win 8.1 / C4D R16 / Maya '16 / 5x GTX 980 Ti
garytyler wrote:I've only had this open for 5 minutes but so far the sliders seem to be updating perfectly!!! Also, the new overlay and rendering bar looks great. Thank you Ahmed!!!
Thx. Hopefully it will be better on every system font setups.
shawnfrueh
Hey Aoktar, I can confirm the issue with the Stop button. I am using the latest version posted here after someone else had brought up this issue. I normally don't use stop but it seems that after pressing the stop button I can no longer use the send button. If I open the dialog on its own and use the send button I can then close that and use the LV Dialog like normal unless I press the stop button again.
I really like the updated Stats bar! Great work!
augdalmo
Hi Aoktar,
I experienced an issue of the use of the new version, when using C4D happen frequent freezing of the work and I just have to use CTR ALT DEL and restart C4D.
I think this happens because I noticed that sometime opens unexpectedly Live Viewer 2.14 even though it is running Live Viewer 2.20 RC2.
It could be due to an incomplete uninstall the plug-in, even if I removed everything from the plugin folder of Octane, as with every new release.I believe, however, that it remained some trace in interface customization.
Have you any suggestions? I can no longer work!
augdalmo wrote:Hi Aoktar,
i have no idea about your system details and workflow. Try to remove all plugins(also octane), make a clean install. Change your driver to latest. Don't save octane windows to layout.
augdalmo
Hallo Aoktar,
many thanks for the fast reply.
my system WIN 8.1 64 bit X5460 16GB C4D R16 GTX780 Titan Black 6GB + K2000 2GB, I will try your suggestions, for the first I have removed my template with Octane Icon, if the problem will be solved I will inform you.
I have noticed that the icon of Octane Dialog and Octane Live viewer ar the same, why?
eyeonestudio
Standalone Development Build Releases 2.21 is Out.... :D
Finally~~ Out-of-core Textures :D
Thanks.. abstrax & aoktar
lucioing
AHMET, THE GREATEST!!!
Almost of you, don't understand what I mean...
Thank you Ahmet!
L
Schermata 2015-02-06 alle 16.22.42.png (28.38 KiB) Viewed 6570 times
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
lucioing wrote:AHMET, THE GREATEST!!!
Thank you Ahmet!
L
thanks. Can't understand what i should see here!
